How to build a custom gstreamer plugin with petalinux sdk
Hi, All
I want to build my own gstreamer plugin for video process.
I created my plugin from github project gst-template-master. It is a template project and compiled with autoconf.
I can get the .so on x86 enviroment. with autogen and ./configure and make.
But when I source the enviroment in petalinux sdk folder, I can only get the .a file with same compile method.
Is there any reference for how to build it.
thanks!
Re: How to build a custom gstreamer plugin with petalinux sdk
Hi @redglass,
Are you trying to create a new plugin or just gstreamer application?
Take a look on gstreamer recipes http://cgit.openembedded.org/openembedded-core/tree/meta/recipes-multimedia/gstreamer?h=rocko
Sandeep
Hi.
I think I want to make plugin
