How to build a minimal PetaLinux image?
I have built an PetaLinux image with Xen package following the reference guide, but I find it takes too much time to boot. It may contains many components I am not interested in.
So, how to build a minimal PetaLinux image? Should I manually select components that I need?
Re: How to build a minimal PetaLinux image?
Hi @hduhxc,
When you create a petalinux project by default it comes with minimal packages as listed below.
IMAGE_INSTALL = "\
		kernel-modules \
		mtd-utils \
		canutils \
		openssh-sftp-server \
		pciutils \
		run-postinsts \
		udev-extraconf \
		packagegroup-core-boot \
		packagegroup-core-ssh-dropbear \
		tcf-agent \
		bridge-utils \
		hellopm \
If you need additional packages to be included then run below command and select the required packages.
$ petalinux-config -c rootfs
Sandeep
Hi @hduhxc,
IMAGE_INSTALL = "\
		kernel-modules \
		mtd-utils \
		canutils \
		pciutils \
		run-postinsts \
		udev-extraconf \
		tcf-agent \
		bridge-utils \
		hellopm \
Sandeep
That is the minimum you will get, but it is more than the minimum required to boot linux, which is what I would call minimal.
What would a system that does not natively have a PCI bus want with pciutils?
And I suspect most systems will have the CAN controllers turned off as well.
What if you even turn off both ethernet controllers?
So the real question is what to do if you want less packages?
Hi @vanmierlo,
If you don't have PCI configured then when you run pciutils it scans and doesn't list any bus.
If you turn off both ethernet controller you can't use network especially if you are using tftpboot then you need to enable ethernet controller.
If you want to remove the packages just disable it as show below.
$ petalinux-config - c rootfs
Filesystem Packages  → console  → utils  → pciutils
Filesystem Packages  → console  → network  → canutils
Filesystem Packages  → misc  → tcf-agent
In <plnx-proj-root>/project-spec/meta-user/conf/petalinuxbsp.conf add this variable to remove dropbear as it is part of core-image.bbclass
PACKAGE_EXCLUDE += "packagegroup-core-ssh-dropbear"
Sandeep
