How to build/compile the Linux application on Zynq
I have a working application built for standalone_os that I want to bring up in Linux. My main problem is how to link the drivers for my IP to the application code. In standalone_os that was acheived by linking the application to the compiled standalone_os library but I can't find any instruction how to acheive it for Linux. I was able to create device-tree .dts file and I see my IP and drivers defined. Is there a well defined flow for this development anywhere.
Please refer to page 66 of the following document:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_6/ug873-zynq-ctt.pdf
