How to build kernel Headers with Petalinux
Hi to all,
I need to use the function dma_alloc_coherent() contained in linux/dma-mapping.h, I have seen that this file is contained in the linux header in my computer. To include all dependences I think is better to include kernel sources in the petalinux build so I can find it in eg: /usr/include/linux and
/usr/include/asm . After I can extract it to a folder, include the path in the XSDK and do an
#include <linux/dma-mapping.h>
to use the function I need. As I do with other libraries (Opencv,ffmpeg)
Is there a command to include the kernel source in the build?
Maybe a file like conf.bb to modify in some Yocto layer?
Many thanks in advance!
Re: How to build kernel Headers with Petalinux
Hi to All, After a some hard days I have found a solution that I going to share.
First Modify the file petalinux-image.bbappend that you can find in the following path:
<plnx-proj-root>/project-spec/meta-user/recipes-core/images/
add the following line:
IMAGE_INSTALL_append = "kernel-devsrc"
Launch petalinux-config -c rootfs
select the kernel source in the following menu:
user packages --> [*] kernel-devsrc
save and launch petalinux-build
If no error occurs, It's done!!
I had the following error: Computing transaction...error: Can't install kernel-devsrc-1.0-r0@plnx_arm: no package provides /bin/awk
It create the rpm package but cannot install it. It's a bug I hope will be patched in next releases
https://patchwork.openembedded.org/patch/136699/
In my opinion that package is provided by busybox and the installer doesn't find it.
Below follow a possible Workaround that I used to install the package.
launch petalinux-config -c rootfs
add the rpm tool, yo can find it in the following position:
Filesystem Packages  --> misc  --> rpm --> [*]rpm
remove the kernel source added before:
user packages --> [ ] kernel-devsrc
launch petalinux-build and flash the new distribution on your SD card.
copy the package kernel-devsrc-1.0-r0.plnx_arm.rpm from
<plnx-proj-root>/build/tmp/deploy/rpm/plnx_arm to a position in your SD card.
Start your system and install it using the following command:
rpm -ivh --nodeps kernel-devsrc-1.0-r0.plnx_arm.rpm
the --nodeps avoid if is following not finding the dependences.
Done!
Done!
Hi I'm using Petalinux 2018.2.
Once I build my solution I cannot inlucde linux/interrupt.h. I think that this library is included in the kernel header and I tried to install tham adding the string "IMAGE_INSTALL_append = "kernel-devsrc" " and adding the package in the rootfs configuration as you said.
I encountered an error about the pythn library, so I added it in the rootfs configuration and the I could build the solution successfully.
But I cannot find again linux/interrupt.h in the generate sysroot.
Any suggestions?
Thank you
after you finished config your kernel <petalinux-config -c kernel>
you must save your kernel setting by specifying save file path which is
<plnx-proj-root>/project-spec/meta-plnx-generated/recipes-kernel/linux/configs/plnx_kernel.cfg
check plnx_kernel.cfg and see whether the setting you wish has been enabled before petalinux-build
rpm -ivh --nodeps kernel-devsrc-1.0-r0.plnx_zynqmp.rpm
when i run the above command i amgetting this error:
rpm: RPM should not be used directly install RPM packages, use Alien instead!
rpm: However assuming you know what you are doing...
Preparing... ################################# [100%]
package kernel-devsrc-1.0-r0.plnx_zynqmp is intended for a different architecture
please help me with this
Rahul
