Observer winston
How to build modified kernel
Hi all,
     I worked with petalinux 2018.1, here I am using ZCU102's BSP, and I did some modification in kernel i2c driver and I am used  petalinux-build command to build, but I did not get any modification in log after boot the board. Any one help me to give the steps to  modify and build the kernel.
Re: How to build modified kernel
Hi Wiston,
You can do this by two methods
Method1:
1. Download same kernel tag from repository
2. modify your changes and create patch using git
3. follow the steps mentioned in this link :http://www.wiki.xilinx.com/PetaLinux+Yocto+Tips section "Patching the Linux Kernel of a PetaLinux Project "
4. petalinux-build
Method 2:
You can build kernel as External kernel source option
Build steps for External source using petalinux:
1. petalinux-config and go to -> Linux Components Selection ---> linux-kernel (ext-local-src)
External linux-kernel local source settings --->/aravind_working_dir/source_code/my_xlnx (EXternal linux-kernel local source path)
2. Go to -> Auto Config Settings and select Specify a manual device tree include directory and enter the path to the new kernel include directory.
Auto Config Settings ---> [*] Specify a manual device tree include directory
(/aravind_working_dir/source_code/my_xlnx/arch/arm64/boot/dts/include) Manual device tree include directory
3. Save and exit petalinux-config
4. Do a petalinux-build
Thanks & regards
Aravind
Hi Wiston,
Method1:
4. petalinux-build
Method 2:
Thanks & regards
Aravind
Observer winston
Hi aravindb,
Thanks for give this information this is very much helpful for me. And I solved this problem.
Winston
Visitor charlie0611
Hi Aravind,
Can you give any examples of how to create the external kernel source for Method 2. I'm assuming that I need to checkout a kernel tree, but what about the device tree include directory? How do I create that?
