How to change si570 clocks on ZCU106 dev-kit using Petalinux .DTSI files
Dear Forum,
I'm building a Petalinux project for the ZCU106 dev-kit, and in the zcu106-reva.dtsi file I can find specific reference to the si570 chip that is setup to drive the User_MGT clock pin. In the zcu106-reva.dtsi file, this si570 is setup as follows.
i2c@3 { /* i2c mw 74 0 8 */
#address-cells = <1>;
#size-cells = <0>;
reg = <3>;
si570_2: clock-generator3@5d { /* USER MGT SI570 - u56 */
#clock-cells = <0>;
compatible = "silabs,si570";
reg = <0x5d>;
temperature-stability = <50>; /* copy from zc702 */
factory-fout = <156250000>;
clock-frequency = <148500000>;
For my design I want the output of this clock to remain at 156.25Mhz.
1) Should I edit the zcu106-reva.dtsi file directly?
If so how Delete or Edit the clock-frequency value..?
2) Should I add the above text to my system-user.dtsi file, with appropriate edits to get 156.25MHz..?
Will settings in the system-user.dtsi file overwrite those in other .dtsi files?
TTFN.
DJE666
Hi ,
You can add node details with required clock value in system-user.dtsi. This will overwrite required value.
You can check wether taht value is reflected or not  by converting  output (system.dtb) to system.dts using below command.
  • dtc -I dtb -O dts -o  system.dts system.dtb
Thanks & Regards
Aravind
Hi Aravind,
Thanks for this data.
Can you please clarify what constitutes the full details of any given NODE in the system? If we take the example that I initially posted, should I put all this text in the system-user.dtsi, a sub-section of it or something else? Here is the original text..
#size-cells = <0>;
reg = <3>;
#clock-cells = <0>;
reg = <0x5d>;
Would the following simple edit to the last line be correct in the system-user.dtsi?
#size-cells = <0>;
reg = <3>;
#clock-cells = <0>;
reg = <0x5d>;
clock-frequency = <156250000>;
DJE666
Hi @dje666,
In system-user.dtsi you can override the clocks as shown below.
/include/ "system-conf.dtsi"
&i2c1 {
    i2cswitch@74 {
        i2c@3 {
            si570_2: clock-generator@5d { /* USER MGT SI570 - u56 */
Sandeep
This is how the device tree is described on my system as the i2c buss on the ZCU106 is connected to a multiplexer
&i2c1 {
    i2c-mux@74 {
        i2c@3 {
                clock-frequency = <125000000>;
If you want to manually build the DTB outside petalinux, you will need to precompile the include folders. This is shown in the wiki below:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/136904764/Creating+Devicetree+from+Devicetree+Generator+for+Zynq+Ultrascale+and+Zynq+7000
gcc -I my_dts -E -nostdinc -undef -D__DTS__ -x assembler-with-cpp -o my_dts/system-top.dts.tmp my_dts/system-top.dts
dtc -I dts -O dtb -o my_dts/system-top.dtb my_dts/system-top.dts.tmp
