redglass
How to check what package I selected for rootfs in petalinux
Hi, All
I used petalinux to build linux for my board.
I want to check what pakages in rootfs I have already selsected.
Is there any file record the select result of petalinux-config -c rootfs.
Thanks!
aravindb
Hi @redglass,
You can find the record of your selected rootfs packages in below file.
vim ./project-spec/meta-plnx-generated/recipes-core/images/petalinux-user-image.bb
Thanks & Regards
Aravind
