How to configure usb as host mode
When I built a Linux system using the ZYNQ series development board, I found that usb0 on the PS side could not be configured as host mode. The initial suspicion is that there is a problem with the devicetree file. The devicetree source code is generated by the SDK, and some code has been modified on the reference wiki.The following picture shows the modification method provided by the wiki.
The Kernel Configuration section has been configured as shown above, the system-top.dts, pcw.dtsi, zynq-7000.dtsi, generated by the SDK I have uploaded。I don't think I need to modify the contents of zynq-7000.dtsi, just configure the mode to host mode in pcw.dtsi.Modify as shown below
The result is unsuccessful and the rest of the functionality is normal. I want to ask if it is because the factors in the picture below cannot be successful. And how do I modify the device tree to configure the USB to host mode.
. Dts files could not be uploaded, so I converted them to c files
Re: How to configure usb as host mode
Hi @yangkejian
Can you please add below changes in your system-user.dtsi file.
vim project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
/include/ "system-conf.dtsi"
&usb0 {
status = "okay";
dr_mode = "host";
Looks your kernel configurations are proper.
Please refer this link for USB host mode jumper settings (page no:23)
https://www.xilinx.com/support/documentation/boards_and_kits/zc702_zvik/ug850-zc702-eval-bd.pdf
Thanks & regards
Aravind
