Observer dyessgg
How to create custom board in Petalinux 2018.1
I have a custom ZynqMP board running Petalinux 2018.1.  All runs well but now I need to add some low-level board-specific code in the Linux kernel and U-Boot.  Investigating the best way to do this, it seems this Petalinux project still references zcu102 board-specific files.
Is there information about the best way to create a new board in Petalinux?  Most of what I have found is quite old (2017.1 and older).
Re: How to create custom board in Petalinux 2018.1
Hi @dyessgg ,
I would recommend you to read the following blog from Adam Taylor, I believe this is what you are looking for:
https://blog.hackster.io/microzed-chronicles-building-petalinux-with-no-bsp-11a9c74946f8
Hope that helps,
Hi @dyessgg ,
Hope that helps,
Observer dyessgg
Thanks for the pointer.  I'm a fan of Adam's and follow as many of his blogs as I can find.
I had not considered this approach for my current situation.  The main reason is I did not create the initial project/BSP and there is a lot of work to start over.
We've finally settled on just using GIT and branching from the mainline code for our specific hardware variations.  This will allow us to integrate any future mainline changes much more easily.
Greg
I'm kind of struggling to understand how to use petalinux for a custom board also.  One of the first steps in UG1144 for creating a custom design from HDF file is to set the MACHINE_NAME to zcu102-rev1.0 (or similar) which I believe adds the zcu102.dtsi file but if you're using a custom board, Its not clear what to set it to... just leave it as template?  Also after creating the project is this way, the u-boot configuration seems to assume you're using the zcu102 board (SUBSYSTEM_UBOOT_CONFIG_TARGET = xilinx_zynqmp_zcu102_rev1_0_defconfig).
Participant itwa-ost
did you find a solution for this? I am at the same point basically and don't know what to put into those fields for a custom board.
Observer dyessgg
It wasn't a high enough priority to pursue at this time so I simply modified the necessary UBoot and Kernel code to customize for my board and left it as a ZCU102.
I hope to revisit this again, but it's unlikely.
Greg
