How to create custom zcu102 image
I have a zcu102 evk board and I want to start with vivado.
According to xilinx manual, zynqmp adds UART port and SD card to IP block, creates image using petalinux tool, and creates BOOT.BIN and image.
After inserting the ub file, I set the boot mode of the board to the SD boot mode and turn it on, but the Uboot message does not appear. Can you see what's wrong?
If you look at the xilinx tutorial, connect clk. I do not know. Where can I find more information on how to boot by adding at least the ip block on the custom board?
what is required to create zcu102 image
Re: How to create custom zcu102 image
You can refer to the below user guides for creating design (Chapter 2 )
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1209-embedded-design-tutorial.pdf
You can also download petalinux bsp and use it to create zcu102 image, see this user guide
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1144-petalinux-tools-reference-guide.pdf
Best Regards
Shabbir
Best Regards
Shabbir
