Participant jcruchaga
How to create jffs2 in Petalinux 2017.3
Hi all,
I need to create my rootfs in the flash memory of my ZCU102 using jffs2.
Here is my petalinux configuration:
ConfigBoot.pngBoot settings
ConfigDTB.pngDTB settingsConfigJFFS2.pngJFFS2 settingsConfigKernel.pngKernel settings
ConfigERASEJFF2s.pngErase block/FStype settingsConfigPartitions.pngPartition settings
Then I built (petalinux-build) my kernel (image.ub)/boot(BOOT.BIN)/rootfs (rootfs.jffs2) and installed them into my flash memory following the uboot commands, load_boot/install_boot, load_kernel, install_kernel, load_jffs2/install_jffs2.
Here is my uboot parameters definition:
ZynqMP> print
autoload=no
baudrate=115200
boot_img=BOOT.BIN
boot_targets=qspi0 <NULL>
bootargs=root=/dev/mtdblock3 rw rootfstype=jffs2
bootcmd=run default_bootcmd
bootdelay=4
bootenv=uEnv.txt
bootenvsize=0x40000
bootenvstart=0x2000000
bootsize=0x2000000
bootstart=0x0
clobstart=0x10000000
console=console=ttyPS0,115200
cp_kernel2ram=sf probe 0 && sf read ${netstart} ${kernelstart} ${kernelsize}
default_bootcmd=run uenvboot; run cp_kernel2ram && bootm ${netstart}
dfu_ram=run dfu_ram_info && dfu 0 ram 0
dfu_ram_info=setenv dfu_alt_info image.ub ram $netstart 0x1e00000
dtb_img=system.dtb
dtbnetstart=0x11800000
eraseenv=sf probe 0 && sf erase ${bootenvstart} ${bootenvsize}
ethact=ethernet@ff0e0000
ethaddr=00:0a:35:00:31:38
fault=echo ${img} image size is greater than allocated place - partition ${img} is NOT UPDATED
fdtcontroladdr=7ff7f420
fileaddr=10000000
filesize=600000
importbootenv=echo "Importing environment from SD ..."; env import -t ${loadbootenv_addr} $filesize
install_boot=sf probe 0 && sf erase ${bootstart} ${bootsize} && sf write ${clobstart} ${bootstart} ${filesize}
install_jffs2=sf probe 0 && sf erase ${jffs2start} ${jffs2size} && sf write ${clobstart} ${jffs2start} ${filesize}
install_kernel=sf probe 0 && sf erase ${kernelstart} ${kernelsize} && sf write ${clobstart} ${kernelstart} ${filesize}
ipaddr=10.228.56.10
jffs2_img=rootfs.jffs2
jffs2size=0x1600000
jffs2start=0x3680000
kernel_img=image.ub
kernelsize=0x1600000
kernelstart=0x2040000
load_boot=tftpboot ${clobstart} ${boot_img}
load_dtb=tftpboot ${clobstart} ${dtb_img}
load_jffs2=tftpboot ${clobstart} ${jffs2_img}
load_kernel=tftpboot ${clobstart} ${kernel_img}
loadaddr=0x10000000
loadbootenv=load mmc $sdbootdev:$partid ${loadbootenv_addr} ${bootenv}
loadbootenv_addr=0x00100000
modeboot=qspiboot
nc=setenv stdout nc;setenv stdin nc;
netboot=tftpboot ${netstart} ${kernel_img} && bootm
netstart=0x10000000
psserial0=setenv stdout ttyPS0;setenv stdin ttyPS0
sd_uEnvtxt_existence_test=test -e mmc $sdbootdev:$partid /uEnv.txt
sd_update_boot=echo Updating boot from SD; mmcinfo && fatload mmc 0:1 ${clobstart} ${boot_img} && run install_boot
sd_update_dtb=echo Updating dtb from SD; mmcinfo && fatload mmc 0:1 ${clobstart} ${dtb_img} && run install_dtb
sd_update_jffs2=echo Updating jffs2 from SD; mmcinfo && fatload mmc 0:1 ${clobstart} ${jffs2_img} && run install_jffs2
sd_update_kernel=echo Updating kernel from SD; mmcinfo && fatload mmc 0:1 ${clobstart} ${kernel_img} && run install_kernel
sdbootdev=0
serial=setenv stdout serial;setenv stdin serial
serverip=10.228.56.30
setup=setenv partid auto
test_crc=if imi ${clobstart}; then run test_img; else echo ${img} Bad CRC - ${img} is NOT UPDATED; fi
test_img=setenv var "if test ${filesize} -gt ${psize}; then run fault; else run ${installcmd}; fi"; run var; setenv var
thor_ram=run dfu_ram_info && thordown 0 ram 0
uenvboot=if run sd_uEnvtxt_existence_test; then run loadbootenv; echo Loaded environment from ${bootenv}; run importbootenv; fi; if test -n $uenvcmd; then echo Running uenvcmd ...; run uenvcmd; fi
update_boot=setenv img boot; setenv psize ${bootsize}; setenv installcmd "install_boot"; run load_boot test_img; setenv img; setenv psize; setenv installcmd
update_dtb=setenv img dtb; setenv psize ${dtbsize}; setenv installcmd "install_dtb"; run load_dtb test_img; setenv img; setenv psize; setenv installcmd
update_jffs2=setenv img jffs2; setenv psize ${jffs2size}; setenv installcmd "install_jffs2"; run load_jffs2 test_img; setenv img; setenv psize; setenv installcmd
update_kernel=setenv img kernel; setenv psize ${kernelsize}; setenv installcmd "install_kernel"; run load_kernel test_crc; setenv img; setenv psize; setenv installcmd
Environment size: 3815/262140 bytes
ZynqMP> print bootargs
ZynqMP>
After that I reset my board and here the final of my output:
[ 92.602093] jffs2: Further such events for this erase block will not be printed
[ 92.609705] jffs2: Node at 0x00623dc8 with length 0x00001044 would run over the end of the erase block
[ 92.618944] jffs2: Perhaps the file system was created with the wrong erase size?
[ 92.626568] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00624000: 0x8379 instead
[ 92.635984] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00624004: 0x536d instead
[ 92.645443] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00624008: 0x9ddb instead
[ 92.654903] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0062400c: 0x2fc4 instead
[ 92.664364] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00624010: 0x3fba instead
[ 92.673826] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00624014: 0x1c5e instead
[ 92.683287] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00624018: 0xcbe2 instead
[ 92.692759] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0062401c: 0x2f2b instead
[ 92.702212] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00624020: 0x5782 instead
[ 92.711671] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00624024: 0x1281 instead
[ 92.721131] jffs2: Further such events for this erase block will not be printed
[ 92.728739] jffs2: Node at 0x00625e50 with length 0x00001044 would run over the end of the erase block
[ 92.737973] jffs2: Perhaps the file system was created with the wrong erase size?
[ 92.745591] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00626000: 0x9f92 instead
[ 92.755006] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00626004: 0x3f8c instead
[ 92.764464] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00626008: 0xe6db instead
[ 92.773925] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0062600c: 0xc764 instead
[ 92.783386] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00626010: 0xd3b2 instead
[ 92.792847] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00626014: 0xe443 instead
[ 92.802316] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00626018: 0x6b0f instead
[ 92.811771] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0062601c: 0x2baa instead
[ 92.821231] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00626020: 0x0d86 instead
[ 92.830718] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00626024: 0x6575 instead
[ 92.840154] jffs2: Further such events for this erase block will not be printed
[ 92.847764] jffs2: Node at 0x00627ed8 with length 0x00001044 would run over the end of the erase block
[ 92.857003] jffs2: Perhaps the file system was created with the wrong erase size?
[ 92.864622] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00628000: 0x1812 instead
[ 92.874036] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00628004: 0x79ee instead
[ 92.883494] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00628008: 0x8256 instead
[ 92.892955] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0062800c: 0x4c88 instead
[ 92.902415] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00628010: 0x1832 instead
[ 92.911884] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00628014: 0x8306 instead
[ 92.921339] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00628018: 0x169e instead
[ 92.930801] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0062801c: 0x5728 instead
[ 92.940261] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00628020: 0x2101 instead
[ 92.949726] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00628024: 0xa0d4 instead
[ 92.959182] jffs2: Further such events for this erase block will not be printed
[ 92.966832] jffs2: Node at 0x00629fdc with length 0x0000002b would run over the end of the erase block
[ 92.976067] jffs2: Perhaps the file system was created with the wrong erase size?
[ 92.983678] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0062a000: 0xa45a instead
[ 92.993092] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0062a004: 0x6d74 instead
[ 93.287397] jffs2: notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) a nd 0 of xref (0 dead, 0 orphan) found.
[ 93.304695] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 93.310891] devtmpfs: mounted
[ 93.313901] Freeing unused kernel memory: 512K (ffffffc000c40000 - ffffffc000cc0000)
[ 93.350764] init[1]: undefined instruction: pc=0000007fa3877900
[ 93.356619] Code: 00000000 00000000 00000000 00000000 (00000000)
[ 93.362810] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004
[ 93.362810]
[ 93.371872] CPU: 1 PID: 1 Comm: init Not tainted 4.9.0-xilinx-v2017.3 #1
[ 93.378540] Hardware name: ZynqMP ZCU102 RevB (DT)
[ 93.383313] Call trace:
[ 93.385750] [<ffffff8008088138>] dump_backtrace+0x0/0x198
[ 93.391128] [<ffffff80080882e4>] show_stack+0x14/0x20
[ 93.396163] [<ffffff80083de514>] dump_stack+0x94/0xb8
[ 93.401198] [<ffffff800812e9a8>] panic+0x114/0x25c
[ 93.405971] [<ffffff800809d898>] complete_and_exit+0x0/0x20
[ 93.411527] [<ffffff800809e810>] do_group_exit+0x38/0xa8
[ 93.416822] [<ffffff80080a84f8>] get_signal+0x240/0x4e0
[ 93.422029] [<ffffff8008087704>] do_signal+0x184/0x550
[ 93.427150] [<ffffff8008087d00>] do_notify_resume+0x90/0xa0
[ 93.432705] [<ffffff8008082ddc>] work_pending+0x8/0x10
[ 93.437823] SMP: stopping secondary CPUs
[ 93.441925] Kernel Offset: disabled
[ 93.445331] Memory Limit: none
[ 93.448372] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004
[ 93.448372]
[ 93.458292] ------------[ cut here ]------------
[ 93.462872] WARNING: CPU: 1 PID: 1 at /home/tecnobit/Escritorio/zcu102_Orig_Custom/xilinx-zcu102-zu9-es1-2017.3/build/tmp/work-share d/plnx_aarch64/kernel-source/kernel/time/tick-broadcast.c:642 tick_handle_oneshot_broadcast+0x1a8/0x1b0
[ 93.483717] Modules linked in:
[ 93.486732]
[ 93.488211] CPU: 1 PID: 1 Comm: init Not tainted 4.9.0-xilinx-v2017.3 #1
[ 93.494896] Hardware name: ZynqMP ZCU102 RevB (DT)
[ 93.499670] task: ffffffc87b876c00 task.stack: ffffffc87b878000
[ 93.505574] PC is at tick_handle_oneshot_broadcast+0x1a8/0x1b0
[ 93.511389] LR is at tick_handle_oneshot_broadcast+0xe8/0x1b0
[ 93.517117] pc : [<ffffff80080f9ea8>] lr : [<ffffff80080f9de8>] pstate: 200001c5
[ 93.524501] sp : ffffffc87ff81e70
[ 93.527791] x29: ffffffc87ff81e70 x28: 0000000000000008
[ 93.533085] x27: ffffff8008d6e000 x26: 00000015c276f8b6
[ 93.538379] x25: ffffff8008cc7000 x24: ffffff8008d6ef70
[ 93.543674] x23: ffffff8008d6ef48 x22: 0000000000000000
[ 93.548969] x21: ffffff8008c96548 x20: 7fffffffffffffff
[ 93.554264] x19: 0000000000000008 x18: 0000000000000010
[ 93.559559] x17: 0000000000000001 x16: 0000007ff4b10198
[ 93.564854] x15: 00000000000003b0 x14: 000000000000001b
[ 93.570148] x13: 0000000000000000 x12: 00000000000003b0
[ 93.575443] x11: ffffff80089694c8 x10: ffffffc87ff88a30
[ 93.580738] x9 : 0000000000000000 x8 : 0000000000000020
[ 93.586033] x7 : 7fffffffffffffff x6 : 00000000f9b018bf
[ 93.591328] x5 : 0000000000000000 x4 : 0000000000000000
[ 93.596623] x3 : 0000000000000001 x2 : 0000000000000002
[ 93.601918] x1 : ffffff8008cde000 x0 : 000000000000000c
[ 93.607212]
[ 93.608689] ---[ end trace 1c0abfce5ddabd10 ]---
[ 93.613290] Call trace:
[ 93.615722] Exception stack(0xffffffc87ff81ca0 to 0xffffffc87ff81dd0)
[ 93.622148] 1ca0: 0000000000000008 0000008000000000 ffffffc87ff81e70 ffffff80080f9ea8
[ 93.629967] 1cc0: 0000000000000400 0000000000000040 0000000100000000 0000000000000001
[ 93.637778] 1ce0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 93.645591] 1d00: 0000000000000000 0000000000000400 0000000000000400 0000000000000001
[ 93.653403] 1d20: 0000000000000001 0000000000000000 ffffffc87ff81d40 ffffff80080c4ea4
[ 93.661215] 1d40: 000000000000000c ffffff8008cde000 0000000000000002 0000000000000001
[ 93.669027] 1d60: 0000000000000000 0000000000000000 00000000f9b018bf 7fffffffffffffff
[ 93.676839] 1d80: 0000000000000020 0000000000000000 ffffffc87ff88a30 ffffff80089694c8
[ 93.684651] 1da0: 00000000000003b0 0000000000000000 000000000000001b 00000000000003b0
[ 93.692462] 1dc0: 0000007ff4b10198 0000000000000001
[ 93.697317] [<ffffff80080f9ea8>] tick_handle_oneshot_broadcast+0x1a8/0x1b0
[ 93.704175] [<ffffff80080fae08>] bc_handler+0x20/0x60
[ 93.709211] [<ffffff80080ed1e8>] __hrtimer_run_queues+0xf0/0x178
[ 93.715198] [<ffffff80080ed578>] hrtimer_interrupt+0x98/0x1c8
[ 93.720929] [<ffffff80086e10b0>] arch_timer_handler_phys+0x30/0x40
[ 93.727092] [<ffffff80080dfa70>] handle_percpu_devid_irq+0x78/0x128
[ 93.733340] [<ffffff80080da774>] generic_handle_irq+0x24/0x38
[ 93.739068] [<ffffff80080dadec>] __handle_domain_irq+0x5c/0xb8
[ 93.744884] [<ffffff80080814cc>] gic_handle_irq+0x64/0xc0
[ 93.750264] Exception stack(0xffffffc87b87ba70 to 0xffffffc87b87bba0)
[ 93.756689] ba60: 0000000000000051 ffffff8008cda9c8
[ 93.764508] ba80: 000000000000c73e 0000000000000000 0000000000000000 ffffff800843f498
[ 93.772320] baa0: ffffff8008d5a247 206c656e72654b20 000000000006d774 0000000000000070
[ 93.780132] bac0: 00000000000027a7 ffffffc87b87b900 69206c6c696b206f ffffff8008d5a245
[ 93.787944] bae0: ffffff8088d5a237 0000000000000006 0000007ff4b10198 0000000000000001
[ 93.795756] bb00: 0000000000000010 ffffff8008d56150 ffffff8008d56150 0000000000000000
[ 93.803568] bb20: ffffff8008d56150 0000000000000000 ffffff8008cc5000 ffffffc87b87bde8
[ 93.811381] bb40: 00000000418004fc ffffffc87b87f5a0 ffffffc87b878000 ffffffc87b87bba0
[ 93.819192] bb60: ffffff800812eaa0 ffffffc87b87bba0 ffffff800812eaa4 0000000060000145
[ 93.827004] bb80: 0000000000000000 ffffff800843f498 0000008000000000 0000000000000000
[ 93.834816] [<ffffff80080827b0>] el1_irq+0xb0/0x140
[ 93.839671] [<ffffff800812eaa4>] panic+0x210/0x25c
[ 93.844445] [<ffffff800809d898>] complete_and_exit+0x0/0x20
[ 93.850001] [<ffffff800809e810>] do_group_exit+0x38/0xa8
[ 93.855295] [<ffffff80080a84f8>] get_signal+0x240/0x4e0
[ 93.860503] [<ffffff8008087704>] do_signal+0x184/0x550
[ 93.865624] [<ffffff8008087d00>] do_notify_resume+0x90/0xa0
[ 93.871179] [<ffffff8008082ddc>] work_pending+0x8/0x10
I've try to modify the erase block size into petalinux config (8,16,32,64) but always the result is the same.
¿Is my procedure correct? ¿Is there any documentation where I can check how to create a jffs2?
Thank you.
