How to determin the interrupt number for zynq ultrascale+ and link to linux interrupt handller
With 2017.3 environment, I was trying to setup a PL logic which interact with Linux on
zynq PS, I'm rather confused and do not know I was doing it right, but here is what I did:
I connected a signal which sends a rising edge to PS's port "pl_ps_irq0[0:0]" after some condition. The block diagram is like this:
I know that a device driver is needed, so I'm also trying to develop the device driver. During the development , there is a function call "request_irq()" from linux kernel which binds a handler to an interrupt number(this is how I understand, is it correct ?).
So the question is where do I get that interrupt number?
I have looked into ug1085 page 314:
Seems the interrupt number should be  121 or 128 since I connected only one signal to it ( am I correct? I also read somewhere else that the interrupt number in dts should subtract 32 somehow.)
I exported the hardware and used the hdf file to configure linux with the petalinux tool:
$ petalinux-config --get-hw-description=<dir containning the hdf>
I exited after the config UI poped up.( This should setup with default config ? )
Build linux with $ petalinux-build
I expected to find the interrupt somewhere in a dts/dtsi file, so I searched and looked in the
<petalinux work dir>/components/plnx_workspace/device-tree/device-tree-generation .
There is a file pl.dtsi in which I found the dts node for my hardware in pl:
	amba_pl: amba_pl@0 {
		#address-cells = <2>;
		#size-cells = <2>;
		compatible = "simple-bus";
		ranges ;
		axi_performance_benchmarker_0: axi_performance_benchmarker@a0000000 {
			compatible = "xlnx,axi-performance-benchmarker-1.0";
			reg = <0x0 0xa0000000 0x0 0x1000>;
			xlnx,m00-axi-addr-width = <0x20>;
			xlnx,m00-axi-burst-len = <0x40>;
			xlnx,m00-axi-data-width = <0x80>;
			xlnx,m00-axi-id-width = <0x1>;
			xlnx,s01-axi-lite-addr-width = <0x6>;
			xlnx,s01-axi-lite-data-width = <0x20>;
		psu_ctrl_ipi: PERIPHERAL@ff380000 {
			compatible = "xlnx,PERIPHERAL-1.0";
			reg = <0x0 0xff380000 0x0 0x80000>;
		psu_message_buffers: PERIPHERAL@ff990000 {
			reg = <0x0 0xff990000 0x0 0x10000>;
but there isn't any interrupts setup in this dts node.
Should I look elsewhere for the interrupt setup or should I do something to tell the petalinux tool to include the interrupt information in my design?(I was expecting that this information can be generated automatically into a dts/dtsi. ).
Or should I just hand code the interrupt information somewhere else so that it can then appear in the device tree after another build?
I also read from ug1085,seems the interrupt from PL is only connected to RPU's GIC(PL390),
and RPU is then connected to GIC-400's distributer in APU :
This seems rather complex, should I program the RPU to process the interrupt also or the petalinux tool have already taken care of that?
I read from 481232 a suggestion to use UIO which eliminates the need for kernel development, I also concern the performance if doing so.
Any suggestions?
Kang
Kang
Re: How to determin the interrupt number for zynq ultrascale+ and link to linux interrupt handller
I think the issue here is the DTG (devicetree generator) is not detecting your interrupt signal. The DTG will look for all ports of type INTERRUPT.
See Line 1793
https://github.com/Xilinx/device-tree-xlnx/blob/master/device_tree/data/common_proc.tcl
Im guessing that your txn_done signal is set to undef, and not intr:
As a workaround, you can update the system-user.dtsi manually in petalinux:
&axi_performance_benchmarker_0 {
interrupt-parent = <&gic>;
interrupts = <0 89 4>;
Or, you can update your IP to set this pin as type interrupt in the IP packager
See Line 1793
Thanks for the answer,
I already get a interrupt number after set pin type to interrupt, it is also 89.
So, Is the number a hardware interrupt number, or a mapped interrupt number?
Is it the number to be used in the "request_irq()"?
Kang
The no . provided by you (89) is hardware supported number.
Flow of IRQ Subsystem is as follows:
request_irq() -> struct irq_chip-> IRQ Domain mapping (Linear map/Tree map etc.)-> IRQ chip GPIO controller -> SoC -> GIC
89 is one taking care by GIC in hardware level.
when it is come to Linux, its no. changes and you can print the same using request_irq()  first argument.
Thanks & Regards
Satish G
G Satish Kumar
Hi gsatish10,
The number 89 is generated by the hardware hdf and petalinux tool,
By "when it is come to Linux, its no. changes and you can print the same using request_irq()  first argument."
do you mean that  the 89 in the dtsi file is the number to put in the first argument of request_irq() (aka request_irq(89,......) )?
Or the number changed in linux so I need to print the number out with some function related to request_irq() ?
I'm a little confused by your statement.
Kang
I was able to query the linux interrupt number by:
struct device_node * np = of_find_node_by_name(NULL,"<node_name>"); // the <node_name> is the one before “@” sign in dtsi file.
int irq_number = irq_of_parse_and_map(np,0);
request_irq(irq_number,......);
so to conclusion, there are 3 interrupt numbers,
the one in ug1085: 121, (this also showed up in one column  in /proc/interrupt after successful insert the kernel module.)
the one in dtsi file: 89,(this one only showed up in dtsi file, so far I can see).
the one mapped by linux.(52, in my case)
still need sometime to figure out clearly.
@stephenm @gsatish10 Thanks.
Kang
