Observer mgillott
How to diagnose Zedboard BTRD vdma Stream On failure ?
I am experimenting with the port of zynq base targeted ref design to zedboard provided by Xylon
The prebuilt image works fine.
When I try to recreate the hardware, petalinux OS and apps using the tools and provided sources, everything works up until the call to turn on the video stream with ioctl(VIDIOC_STREAMON..) which fails
I found I can turn on debug messages from the v4l2 layer using :-
                           echo 10 > /sys/module/videobuf2_core/parameters/debug
and when I do this I can see the messages :-
vb2: vb2_buffer_done: done processing on buffer 0, state: 3
vb2: vb2_buffer_done: done processing on buffer 1, state: 3
vb2: vb2_start_streaming: driver refused to start streaming
so I guess this is a problem in the xilinx video driver. (vdma / tpg / vtc)
My question is, how can I dig into this further to find the root cause  ?
Malcolm
Observer xylonsupport
Re: How to diagnose Zedboard BTRD vdma Stream On failure ?
Hi Malcom,
Could you send us the whole Linux kernel boot log?
Xylon Support
