Observer dmitril
How to disable device tree generation?
Our FPGA has several module instances that share the same IRQ. This works OK, but I cannot build Petalinux. It fails in device-tree task with various errors (see below).
I cannot waste time on this clumsy device tree generation tool and instead I would like to make a custom .dts file.
Question is how to prevent Petalinux from running device-tree task
or, at least, that part of device-tree task that generates .dts from .hdf
These are the errors from generate_target:
ERROR: [Hsi 55-1545] Problem running tcl command ::sw_device_tree::generate : missing operator at _@_
in expression "84 _@_85 85 85 85 85 85 85 -..."
(parsing expression "84 85 85 85 85 85 85 8...")
invoked from within
"expr $intr_id - 32"
or (after we modified FPGA):
| WARNING: Interrupt pin "mm2s_introut" of IP block: "axi_vdma_cam_3_ddr" is not connected to any interrupt controller
| WARNING: Interrupt pin "s2mm_introut" of IP block: "axi_vdma_cam_3_ddr" is not connected to any interrupt controller
| WARNING: not supported pl_clk:
| ERROR: axi_vdma_cam_0: s2mm_introut port is not connected
| ERROR: [Hsi 55-1545] Problem running tcl command ::sw_axi_vdma::generate : ERROR: axi_vdma_cam_0: s2mm_introut port is not connected
| while executing
| "error "ERROR: ${drv_handle}: s2mm_introut port is not connected""
Thank you
Re: How to disable device tree generation?
Hi @dmitril
Try disabling Device tree Auto config from petalinux-config -> Auto config settings
and see if that matches to your requirement
Best Regards
Shabbir
Hi @dmitril
Best Regards
Shabbir
Observer dmitril
Yes,
changing
CONFIG_SUBSYSTEM_AUTOCONFIG_DEVICE__TREE=y
to
# CONFIG_SUBSYSTEM_AUTOCONFIG_DEVICE__TREE is not set
seem to work
Thank you
