Participant haibingma
How to enable EEPROM and saveenv for zc702 board?
I want to enable eeprom and saveenv for zc702 board. I wonder anybody successfully did that. What shall I set in the zynq_zc702.h file of the u-boot? Do I need to save some initial content to eeprom first?
Haibing
Re: How to enable EEPROM and saveenv for zc702 board?
Hi Haibing,
I attached a patch that I had tested on 702.  See if it helps you.
I got this working on a little bit older version of the u-boot, the 14.2 trd release.
the save env command is then used to save the environment.  This will let you set the mac address uniquely on a board as that was why I worked on it a bit.
Thanks a lot John. It works very well for me.
Haibing
