04-09-2010 07:56 AM
Hello all,
I'm trying to create a system with a MMU but when i run the BSB wizard nothing appears...Can someone help me?
Another question, i need to install a Linux OS in my desktop to create the linux kernel?
04-09-2010 08:09 AM
You'll need to go into the system assembly view and configure the microblaze manually to change the parameterst to enable the MMU. You should really start with a known good reference design the first time you do this - otherwise you're going to run into a lot of trouble.
Yes you'll need Linux to run to the tools - or a vmware (or equivalent) setup.. Good luck, don't forget to read everything at http://xilinx.wikidot.com.
Terry
04-09-2010 08:09 AM
Terry
04-09-2010 09:10 AM
05-26-2010 12:41 PM
Hi jflima,
I want to enable (same as you ) MMU to my ML507 Virtex 5 Kit....I have some error about time constraint...some timing stuff to resolve in system.ucf....
Tell me ...did you solve a working MMU system...?...
...what reference did you use ?
Thanks...
