How to enforce rebuilding of rootfs in Petalinux?
I have a package that contains only script files. Unfortunately, when I modify its contents and run:
petalinux-build
the rootfs.cpio.gz is not recreated, and the generated initramfs still contains the old scripts.
I've tried to explicitly clean my package:
petalinux-build -c my-package -x clean
petalinux-build
but it also doesn't help.
The only way to refresh the initramfs is to do:
petalinux-build -x mrproper
petalinux-build
which is not a solution, as it takes one hour.
Is there any faster method to enforce recreating the initramfs with the new scripts?
I've managed to rebuild the rootfs.cpio.gz by the following sequence of operations:
petalinux-build -c my-package -x do_cleanall
petalinux-build -c rootfs -x do_cleanall
petalinux-build
It is still quite slow, but much faster than using "mrproper".
Hello @wzab,
I'm using Vivado 2017.2 and I do a slightly different sequence of commands. You could try and check if it's faster:
petalinux-build -c your_app -x do_clean
petalinux-build -x do_populate_sysroot
petalinux-build -x package
Since I'm packaging a BOOT.BIN and image.ub to boot from SDCard, my final command is a
petalinux-package --boot --fsbl <...> --fpga <...> --u-boot --force
Not sure if you need that last one.
Actually I run that sequence in only one shell command line:
petalinux-build -c your_app -x do_clean && petalinux-build -c your_app &&  petalinux-build -x do_populate_sysroot && petalinux-build -c rootfs && petalinux-build -x package && petalinux-package [...]
regards
Brasilino
(Using petalinux 2018.2):
Here's a workaround I've found that's a little sloppy, but doesn't take an hour.  The problem I was specifically trying to solve was how to force a rebuild of the initramfs after I made a change that updated the contents of one of my user packages.  FYI the user package also had issues rebuilding after source changes, so I actually have to rebuild it as well:
petalinux-build -c my-package -x cleanall && petalinux-build -c my-package
petalinux-config -c rootfs
(add or remove a spurious debug utility program)
petalinux-build
The process of petalinux-build will kickoff initramfs construction tasks in the kernel recipe after rootfs is rebuilt.  Here are two other things I tried that DIDN'T help:
1. petalinux-build -c kernel -x do_bundle_initramfs -f won't work because it does not force rootfs to be rebuilt, this task appears to be executed after rootfs is done.
2. petalinux-build -c rootfs -x do_rootfs -f won't work because "ERROR: Force building is not supported for image targets"
I also encountered this issue and did a bit more digging.  I believe the underlying issue relates to versioning of the the package.  If petalinux/yocto cannot determine the version, it assigns a default version (i.e. 1.0-r0 or something similar) and if the version does not change then the package is assumed the same and the dependencies do not get rebuilt correctly.
In my case, I am in development and pulling the package source from a git repository.  The repository changes, but I don't update the receipe.
Adding:
PV = "0.0-git${SRCPV}"
 to the recipe makes the version depend on the git revsion and cause a rebuild of the rootfs when my package changes.
Applicable documentation:
https://www.yoctoproject.org/docs/1.8/ref-manual/ref-manual.html#var-AUTOREV
https://www.yoctoproject.org/docs/1.8/ref-manual/ref-manual.html#var-PV
https://www.yoctoproject.org/docs/1.8/ref-manual/ref-manual.html#var-SRCPV
