How to erase the whole QSPI Flash by XIlinx SDK?
How to erase the whole QSPI Flash by XIlinx SDK? I'd like to erase all the contents of flash at one time.
Re: How to erase the whole QSPI Flash by XIlinx SDK?
Hi @xilinx-zhaosheng
There is no way to erase the whole QSPI flash from the SDK as the program_flash utility only erases the size of the file that you are actually writing.
You have two options:
1. Use Vivado hardware manager to erase the entire flash
2. Boot up to u-boot (ej. from SD card) and erase the flash device through sf probe
Ibai
Detailed step method using vivado hardware manager to erase the entire flash?
