How to generate .so with petalinux?
  I am testing a dma project from guthub https://github.com/bperez77/xilinx_axidma , but I have a problem when I was building the project , as the picture shows
 this is a problem about the library ,and I want to know how to compile the library to generate .so file with petalinux , I tried to compile the library with arm-linux-gnueabihf- ,but the peyalinux seems to cannot link the .so wtth arm-linux-gnueabihf . So , do you have ever encounted such problems , and how did you solved such problems?
Re: How to generate .so with petalinux?
To create library in petalinux, refer to https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842475/PetaLinux+Yocto+Tips
I mean you need to make another recipe for library
Then add DEPENDS and RDEPENDS  to your application recipe like this
DEPENDS += "libsample"
RDEPENDS += "libsample"
The RFDC driver from xilinx is delivered as a .SO file in Linux. You can use this as a reference. See the MakeFile.Linux:
https://github.com/Xilinx/embeddedsw/tree/master/XilinxProcessorIPLib/drivers/rfdc/src
The recipe for this can be seen here:
https://github.com/Xilinx/meta-petalinux/blob/master/recipes-bsp/rfdc/rfdc_git.bb
Thanks for your advice.
