Observer ishahak
How to get rid of "spidev spi1.0: buggy DT: spidev listed directly in DT"
I'm using the UltraZed SOM. Having a kind of "cosmetic" question please.
I'm having 3 SPI devices which I modify like this in system-user.dtsi:
&spi0{
   #address-cells=<1>;
   #size-cells=<0>;
   status = "okay";
   spidev@0{
      compatible="spidev";
      reg =<0>; //chipselect 0
      spi-max-frequency= <3125000>;
   spidev@1{
      reg =<1>; //chipselect 1
   spidev@2{
      reg =<2>; //chipselect 2
This works fine, but each of the 3 is producing a 66-lines complained while booting, starting with "spidev spi1.0: buggy DT: spidev listed directly in DT".
Reading here, I have learned that it is a new change, described as follows:
The commit message reads:
    spi: spidev: Warn loudly if instantiated from DT as "spidev"
    Since spidev is a detail of how Linux controls a device rather than a
    description of the hardware in the system we should never have a node
    described as "spidev" in DT, any SPI device could be a spidev so this
    is just not a useful description.
    In order to help prevent users from writing such device trees generate a
    warning if spidev is instantiated as a DT node without an ID in the match
    table.
    Signed-off-by: Mark Brown <broonie@kernel.org>
So my question is:
What is the "right way" to include SPI devices in a way that will not lead the kernel to complain?
EDIT - added this:
Is there a way to modify this line:
so that the kernel will not complain, and still the spidev assignment will keep working as it is now?
Thanks!
-Itay
Observer ishahak
Re: How to get rid of "spidev spi1.0: buggy DT: spidev listed directly in DT"
Solved my own problem by looking here.
I was adapting their "quick and dirty" solution.
Setting the compatibility like this:
comptabile = "rohm,dh2228fv"; /* Same as "spidev" but without errors at boot. Search "buggy DT" to understand */
did successfully eliminate the annoying warnings.
Observer ishahak
