Observer c.gianni
How to halt a program executing under OSL Linux
I, I just installed linux under my custom Virtex 5 board, I have this problem:
If I run any command, ping for example, once started I'm not able to halt it, when I try to press CTRL+C I got only the message "#Application running" and then nothing.. Is there another hotkey combination that I got to press in order to halt the execution?
Re: How to halt a program executing under OSL Linux
please go throug the below links regarding the control-c console issue
http://forums.xilinx.com/t5/Embedded-Linux/Microblaze-linux-on-SP605-does-not-respond-to-command-if/m-p/59633
Madhubala
Observer c.gianni
Ok, I understand that the problem is BusyBox, when I use telnet the problem does not manifest. However, from the other posts is not clear what is the solution
