How to improve ethernet forwarding throughput
Hi all.
I'm a software guy.I use customboard based on ZC706.
My board has two Ethernet. I will call them eth0 and eth1.
I measured throughput when forwarding from eth1 to eth0 and loopback.
The result was around 16,000 fps.
I thought it is CPU resource limit. Because I checked CPU uses by "sar".
%soft value was below. My board has two cores.
all : 50
0 : 100
1 : 0
I want to improve ethernet forwarding throughput even if only slightly.
If I say hope,  to 100,000 fps.
Could you tell me about infomation about improving throughput?
Thank you.
