Observer johnmccaskill
How to include U-Boot's "fw_printenv" tool in Petalinux 2016.4 rootfs
I want to include the U-Boot fw_printenv program in a PetaLinux 2016.4 rootfs
This message: https://forums.xilinx.com/t5/Embedded-Linux/How-to-include-U-Boot-s-quot-fw-printenv-quot-tool-in-Petalinux/td-p/732538
Shows the basics of how to include the U-Boot fw_printenv program in the PetaLinux 2016.3 rootfs, but enough details have changed between 2016.3 and 2016.4 that this method does not work for 2016.4.
Does anyone know the new way to do this?
John
Observer derekparks
Re: How to include U-Boot's "fw_printenv" tool in Petalinux 2016.4 rootfs
@johnmccaskill, Were you able to solve the issue?  I'm using 2017.3, but still would like to know if its easily possible before i start diving into the petalinux framework.
Hi @johnmccaskill@derekparks,
Add below line in <plnx-proj-root>/project-spec/meta-user/conf/petalinuxbsp.conf
IMAGE_INSTALL_append += " \
u-boot-fw-utils \ "
Note: This is not officially supported from Xilinx. But we don have a road to add this in future release.
Sandeep
Observer derekparks
Thank you...worked for me....using 2017.3 with Petalinux u-boot source and configuration
