Voyager
Voyager
How to install the libtiff.so.5 library
I'm working with petalinux 2018.2 tools and zynq ultrascale+.
I'm trying to add and build a pre-compiled (arm64) third party library, but after following theUG1144 (page 58) steps, I've got the next dependency error:
ERROR: Nothing RPROVIDES 'libtiff.so.5' (but ~/hdl/dev/Petalinux_test/Petalinux/uz7ev_evcc_2018_2/project-spec/meta-user/recipes-apps/libm3api/libm3api.bb RDEPENDS on or otherwise requires it)
Thinks I've tried:
-Add the tiff library (in misc) and tiff dev tools in rootfs
-Add RDEPENDS_${PN} += "libtiff.so.5" in the lib recipe.
I tried to look for the libtiff.so.5 library and I couldn't find it within the petalinux project.
how could I install the libtiff.so.5 library in petalinux? is it possible?
Thanks in advance.
Voyager
Voyager
Re: How to install the libtiff.so.5 library
I finally solved this adding the tiff library and doing a clean petalinux build, running first: "petalinux-build -x mrproper" and then a normal build, hope this can give some clues to someone with similar issue...
Voyager
Voyager
