How to link dbus in example source code in petalinux 2019.1?
Dear all.
I'm trying to build dbus-server / client sample code in petalinux 2019.1.
Firstly, I enable dbus and dbus-glib using petalinux-config -c rootfs (base -> dbus & dbus-glib)
And I generated dbus apps and modified dbus-server.bb to link and include dbus and dbus-glib.
When I build example source code, error code of build is as following:
| dbus-server.c:35:10: fatal error: dbus/dbus.h: No such file or directory
| #include <dbus/dbus.h>
I doesn't have enough understood of yocto  and .bb so I can't catch what problem is.
My .bb file is as following.
1 #
2 # This file is the dbus-server recipe.
3 #
4
5 SUMMARY = "Simple dbus-server application"
6 SECTION = "PETALINUX/apps"
7 LICENSE = "MIT"
8 LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
9
10 SRC_URI = "file://dbus-server.c \
11 file://Makefile \
12 file://
13 "
14
15 S = "${WORKDIR}"
16 DEPENDS = "dbus dbus-glib dbus-glib-native glib-2.0 glib-2.0-native"
17
18 do_compile() {
19 ${CC} ${CFLAGS} ${LDFLAGS} -o dbus-server dbus-server.c -ldbus-glib -ldbus
20 }
21
22 do_install() {
23 install -d ${D}${bindir}
24 install -m 0755 dbus-server ${D}${bindir}
25 }
26
27 FILES_${PN} += " dbus-server"
Could you guide me to solve this problem?
If you add any comment, it will be very helpful to me. Thanks.
Re: How to link dbus in example source code in petalinux 2019.1?
Here is my self solution.
I hope it is helpful to you when meet similar problem like this topic.
1 #
3 #
4
7 LICENSE = "MIT"
9
12 "
13
14 S = "${WORKDIR}"
15 DEPENDS = "dbus dbus-glib glib-2.0"
16
17
18 do_compile() {
19 #oe_runmake
20 ${CC} ${LDFLAGS} -I=/usr/include/dbus-1.0 \
21 -I=/usr/lib64/dbus-1.0/include \
22 -I=/usr/include/glib-2.0 \
23 -I=/usr/lib64/glib-2.0/include \
24 dbus-server.c -o dbus-server \
25 -L=/usr/lib64/libdbus-1.so \
26 -L=/usr/lib64/libdbus-glib-1.so \
27 -L=/usr/lib64/libglib-2.0.so \
28 -ldbus-1 -ldbus-glib-1 -lglib-2.0
29 }
30
31 do_install() {
32 install -d ${D}${bindir}
33 install -m 0755 dbus-server ${D}${bindir}
34 }
1 #
3 #
4
7 LICENSE = "MIT"
9
12 "
13
14 S = "${WORKDIR}"
16
17
18 do_compile() {
19 #oe_runmake
29 }
30
31 do_install() {
34 }
Better .bb file and Makefile config in yocto.
In recipes/dbus-server .bb file is as following.
1 #
3 #
4
7 LICENSE = "MIT"
9
12 file://in.softprayog.dbus-server.conf \
13 "
14
15 S = "${WORKDIR}"
16 DEPENDS += "dbus dbus-glib glib-2.0"
17
18 CFLAGS_append += "-I ${S}/recipe-sysroot/usr/include/dbus-1.0"
19 CFLAGS_append += "-I ${S}/recipe-sysroot/usr/lib64/dbus-1.0/include"
20
21
22
23 do_compile() {
24 oe_runmake
25 }
26
27 do_install() {
28 install -d ${D}${bindir}
29 install -m 0755 dbus-server ${D}${bindir}
30 install -d ${D}/etc/dbus-1/system.d/
31 install -m 0755 in.softprayog.dbus-server.conf ${D}/etc/dbus-1/system.d/in.softprayog.dbus-server.conf
32 }
Makefile
1 APP = dbus-server
2
3 # Add any other object files to this list below
4 APP_OBJS = dbus-server.o
5
6 all: build
7
8 build: $(APP)
9
10 $(APP): $(APP_OBJS)
11 $(CC) $(LDFLAGS) -o $@ $(APP_OBJS) $(LDLIBS) -ldbus-1 -ldbus-glib-1
12
13 clean:
14 -rm -f $(APP) *.elf *.gdb *.o
I build and test dbus server/client example in https://www.softprayog.in/programming/d-bus-tutorial.
I used petalinux 2019.1.
