sonminh
How to modify device-tree once linux runtime?
My project is using SW Update follow link to update BOOT.BIN, image.ub, rootfs.jffs2 into flash on zcu102:
https://www.zachpfeffer.com/single-post/Integrate-SWUpdate-into-a-PetaLinux-Project
I have finished integrate SW Update into rootfs and boot successfull, and I can access webserver as image I attached.
I plan to reserve 2 partition on flash: one partition for update and one partition for load rootfs, image.ub, boot.bin:
flash@0 {
compatible = "n25q512a", "micron,m25p80";
#address-cells = <0x1>;
#size-cells = <0x1>;
reg = <0x0>;
spi-tx-bus-width = <0x1>;
spi-rx-bus-width = <0x4>;
spi-max-frequency = <0x66ff300>;
partition@0x00000000 {
label = "boot";
reg = <0x0 0xf00000>;
partition@0x00f00000 {
label = "bootenv";
reg = <0xf00000 0x40000>;
partition@0x00f40000 {
label = "kernel";
reg = <0xf40000 0x1400000>;
partition@0x02340000 {
label = "jffs2_3";
reg = <0x2340000 0xf00000>;
partition@0x03240000 {
label = "boot_1";
reg = <0x3240000 0xf00000>;
partition@0x04140000 {
label = "kernel_1";
reg = <0x4140000 0x1400000>;
partition@0x05540000 {
label = "jffs2_6";
reg = <0x5540000 0xf00000>;
partition@0x06440000 {
label = "user data";
reg = <0x6440000 0x1400000>;
chosen {
bootargs = "earlycon clk_ignore_unused root=mtd:jffs2_3 rw rootfstype=jffs2 rootwait";
stdout-path = "serial0:115200n8";
With rootfs.jffs2, May be I must need to override this in the kernel arguments in device-tree from user linux to load rootfs.jffs2 from partition jffs2_6:
chosen {
How to modify bootargs in device-tree once linux runtime?
Thanks and best regards
watari
Hi @sonminh
How about regenerating fit image file by mkimage ?
Best regards,
sonminh
Hi @watari ,
I want to modify bootarg in device-tree from linux user after booted, not U-boot
watari
Hi @sonminh
FIT image file is able to generated by mkimage (*1).
As you know there is argument of linux kernel in device tree blob file.
So, I suggest you to use it after booted. It's basic procedure in linux world. (For example, it is adopted in Ubuntu, Debian and so on.)
By the way, do you want to overlay device tree ?
*1)
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842374/U-Boot+Images
Best regards,
sonminh
Hi @watari,
I have read link that you provide. But I'm sorry because I don't understand how to modify bootargs in device-tree to load rootfs from differrent partition once runtime:
chosen {
Can you talk clearly about procedure?
watari
Hi @sonminh
Here are solution.
# Temporally change rootfs
You can use chroot command to change root directory.
ex.
mount /dev/sdb1 /mnt/sdb1
cd /mnt/sdb1
mount -t proc proc proc/
mount -t sysfs sys sys/
mount -o bind /dev dev/
chroot /mnt/sdb1
# Permanetlly change rootfs
As I already mentioend, you can update fit image by using mkimage and so on.
Best regards,
