How to prevent GTK/X11/Wayland packages to be built (for image size reduction)
Hi guys,
I would like to optimize the rootFS size for my custom board. Is there an easy way to get the list of "atomic" packages using petalinux-config -c rootfs, and their corresponding dependencies ? When I build petalinux image, I can see that some graphical packages are built while not expected, and I would like to know where they come from.
Thanks !
For anybody whos wants to reduce the produced iamge size by removing any graphical package.
I've added X11 to the list of yocto DISTRO_FEATURES I want to remove from my build :
in file ./project-spec/meta-user/conf/petalinuxbsp.conf, I've added the follwing line :
DISTRO_FEATURES_remove = " x11"
I've relaunched a build and here is what I get :
WARNING: You have included the meta-gnome layer, but 'x11' has not been enabled in your DISTRO_FEATURES. Some bbappend files may not take effect. See the meta-gnome README for details on enabling meta-gnome support.
 Somewhere, meta-gnome layer is selected. I've found this AR from Xilinx :
https://www.xilinx.com/support/answers/72139.html
--> meta-gnome seems to be selected because X11 is the default mali-backend even if X11 distro feature is removed : https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841928/Xilinx+Arm+Mali-400+Driver
So I've removed everything graphical
DISTRO_FEATURES_remove = " ipv6 ssh-server-dropbear x11 wayland mali fbdev opengl bluetooth"
MALI_BACKEND_DEFAULT = "fbdev"
... but I'm still building Gnome packages...
