bhuang2
How to read local MAC address from eeprom for ethernet device during booting the kernel?
Hi everyone,
In the past, the *ppc* linux had a piece of code in its simple bootloader to retrieve local MAC address from  eeprom.  When the community migrate to *powerpc* linux, it seems that we can only
a) hard-code a MAC address in the device tree file in advance
b) use i2c eeprom interface at user space after booting into the kernel
for accessing MAC address.
In my situation, I have tens of FPGA boards running in parallel. It makes the first approach very inconvenient to me because I don't want to hard-code every MAC address for all of the boards. However, since each FPGA board use NFS rather than Ramdisk for its own run-time environment (believe or not, its size is larger than a 512MB DDR2 can host), I need to retrieve local MAC address for ethernet device before the kernel send DHCP requests to the server.
I spent last few days playing around with u-boot. I thought it would pass the local MAC address to the kernel but it didn't. Every time when the kernel boots up, the hard-code MAC address in dtb file just overwrite the local MAC address. Am I wrong here? Any idea?
Ben
bhuang2
I am able to pass MAC address from u-boot to the kernel now. Thank you.
Hello bhuang,
how did you do that? I wanted to pass the cmdline arguments of the kernel via uboot but it also always took the hardcoded cmdlin from the dts file.
Can you give me any hints?
Marco
