dongkesi
How to remove compiler flag in petalinux
I want to change the compiler options in petalinux for FSBL. I know how to modify compile options in the SDK IDE, and I also know how to add Patch for FSBL in petalinux. But how to patch the compiler's configuration? For example, I want to remove the compile option "-Os -flto -ffat-lto-objects". I searched everywhere in embeddedsw, then comment them and make a patch, but it doesn't work.
First two patches work.
0001-sw_apps-zynqmp_fsbl-add-SI5338-configuration.patch
0002-sw_apps-zynqmp_fsbl-add-ethernet-reset.patch
0003-sw_apps-zynqmp_fsbl-fix-XFSBL_ERROR_PH_CHECKSUM_FAIL.patch
From 207de132a0a160dc6d24d28a4a31d27c466ef54f Mon Sep 17 00:00:00 2001
Date: Mon, 16 Sep 2019 10:45:48 +0800
Subject: [PATCH 3/3] sw_apps: zynqmp_fsbl: fix XFSBL_ERROR_PH_CHECKSUM_FAILED
 issue
 XilinxProcessorIPLib/drivers/cpu_cortexa53/data/cpu_cortexa53.tcl | 2 +-
 XilinxProcessorIPLib/drivers/cpu_cortexr5/data/cpu_cortexr5.tcl   | 2 +-
 lib/sw_apps/zynqmp_fsbl/data/zynqmp_fsbl.tcl                      | 6 +++---
 lib/sw_apps/zynqmp_fsbl/misc/makefile                             | 2 +-
 lib/sw_apps/zynqmp_fsbl/src/Makefile                              | 6 +++---
 5 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/XilinxProcessorIPLib/drivers/cpu_cortexa53/data/cpu_cortexa53.tcl b/XilinxProcessorIPLib/drivers/cpu_cortexa53/data/cpu_cortexa53.tcl
index 0b08beb..cb8bc1c 100644
--- a/XilinxProcessorIPLib/drivers/cpu_cortexa53/data/cpu_cortexa53.tcl
+++ b/XilinxProcessorIPLib/drivers/cpu_cortexa53/data/cpu_cortexa53.tcl
@@ -115,7 +115,7 @@ proc xdefine_cortexa53_params {drvhandle} {
 		set extra_flags [common::get_property CONFIG.extra_compiler_flags [hsi::get_sw_processor]]
 		#Append LTO flag in EXTRA_COMPILER_FLAGS if not exist previoulsy.
 		if {[string first "-flto" $extra_flags] == -1 } {
-			append extra_flags " -Os -flto -ffat-lto-objects"
+			#append extra_flags " -Os -flto -ffat-lto-objects"
 			common::set_property -name {EXTRA_COMPILER_FLAGS} -value $extra_flags -objects [hsi::get_sw_processor]
diff --git a/XilinxProcessorIPLib/drivers/cpu_cortexr5/data/cpu_cortexr5.tcl b/XilinxProcessorIPLib/drivers/cpu_cortexr5/data/cpu_cortexr5.tcl
index 6dcb8b7..a7db1c2 100644
--- a/XilinxProcessorIPLib/drivers/cpu_cortexr5/data/cpu_cortexr5.tcl
+++ b/XilinxProcessorIPLib/drivers/cpu_cortexr5/data/cpu_cortexr5.tcl
@@ -139,7 +139,7 @@ proc xdefine_cortexr5_params {drvhandle} {
diff --git a/lib/sw_apps/zynqmp_fsbl/data/zynqmp_fsbl.tcl b/lib/sw_apps/zynqmp_fsbl/data/zynqmp_fsbl.tcl
index 20b5d58..037ebde 100644
--- a/lib/sw_apps/zynqmp_fsbl/data/zynqmp_fsbl.tcl
+++ b/lib/sw_apps/zynqmp_fsbl/data/zynqmp_fsbl.tcl
@@ -327,7 +327,7 @@ proc swapp_generate {} {
         file delete -force $trans_tbl_a53_64
         file delete -force $trans_tbl_a53_32
-        set new_flags "-Wall -fmessage-length=0 -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -DARMR5 -Os -flto -ffat-lto-objects $def_flags"
+        set new_flags "-Wall -fmessage-length=0 -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -DARMR5 $def_flags"
     } else {
         set compiler [common::get_property CONFIG.compiler $proc_instance]
@@ -339,7 +339,7 @@ proc swapp_generate {} {
             file rename -force $trans_tbl_a53_32 $trans_tbl_a53
-            set new_flags "-Wall -fmessage-length=0 -march=armv7-a -mfpu=vfpv3 -mfloat-abi=hard -DARMA53_32 -Os -flto -ffat-lto-objects $def_flags"
+            set new_flags "-Wall -fmessage-length=0 -march=armv7-a -mfpu=vfpv3 -mfloat-abi=hard -DARMA53_32 $def_flags"
         } else {
             #A53 64-bit
             set ld_file "lscript.ld"
@@ -352,7 +352,7 @@ proc swapp_generate {} {
             file rename -force $trans_tbl_a53_64 $trans_tbl_a53
-            set new_flags "-Wall -fmessage-length=0 -DARMA53_64 -Os -flto -ffat-lto-objects $def_flags"
+            set new_flags "-Wall -fmessage-length=0 -DARMA53_64 $def_flags"
diff --git a/lib/sw_apps/zynqmp_fsbl/misc/makefile b/lib/sw_apps/zynqmp_fsbl/misc/makefile
index e8ad2a7..1085af3 100755
--- a/lib/sw_apps/zynqmp_fsbl/misc/makefile
+++ b/lib/sw_apps/zynqmp_fsbl/misc/makefile
@@ -9,7 +9,7 @@ endif
 ifeq "${PROC}" "r5"
 PROCESSOR = zynqmp_fsbl_bsp/psu_cortexr5_0
 endif
-LTO_FLAGS = -Wall -Wextra -Os -flto -ffat-lto-objects
+LTO_FLAGS = -Wall -Wextra
 OTHER_FLAGS = -mfpu=vfpv3 -mfloat-abi=hard
 LIBRARIES = ${PROCESSOR}/lib/libxil.a
diff --git a/lib/sw_apps/zynqmp_fsbl/src/Makefile b/lib/sw_apps/zynqmp_fsbl/src/Makefile
index 6ca5077..4722d53 100644
--- a/lib/sw_apps/zynqmp_fsbl/src/Makefile
+++ b/lib/sw_apps/zynqmp_fsbl/src/Makefile
@@ -55,7 +55,7 @@ AS      :=      $(CROSS)armr5-none-eabi-gcc
 LINKER  :=      $(CROSS)armr5-none-eabi-gcc
 DUMP    :=      $(CROSS)armr5-none-eabi-objdump -xSD
 CFLAGS :=  -Wall -O0 -g3 -fmessage-length=0
-ECFLAGS := -g -DARMR5 -Wall -Wextra -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -Os -flto -ffat-lto-objects
+ECFLAGS := -g -DARMR5 -Wall -Wextra -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16
 LSCRIPT := -Tlscript.ld
 EXEC := ron_r5_fsbl.elf
 INCLUDEPATH := -I$(BSP_DIR)/psu_cortexr5_0/include -I. -I../misc/$(BOARD)/$(PROC) -I../misc/$(BOARD)
@@ -77,7 +77,7 @@ CC      :=      $(CROSS)aarch64-none-elf-gcc
 AS      :=      $(CROSS)aarch64-none-elf-gcc
 LINKER  :=      $(CROSS)aarch64-none-elf-gcc
 DUMP    :=      $(CROSS)aarch64-none-elf-objdump -xSD
-ECFLAGS = -march=armv8-a -DARMA53_$(A53_STATE) -Os -flto -ffat-lto-objects
+ECFLAGS = -march=armv8-a -DARMA53_$(A53_STATE)
 LSCRIPT := 	-Tlscript_a53.ld
 LDFLAGS := -Wl,--start-group,-lxil,-lxilffs,-lxilsecure,-lxilpm,-lgcc,-lc,--end-group -L$(LIBPATH) -L./ -Wl,--build-id=none
 else
@@ -85,7 +85,7 @@ CC      :=      $(CROSS)arm-none-eabi-gcc
 AS      :=      $(CROSS)arm-none-eabi-gcc
 LINKER  :=      $(CROSS)arm-none-eabi-gcc
 DUMP    :=      $(CROSS)arm-none-eabi-objdump -xSD
-ECFLAGS :=  -Wextra -march=armv7-a -mfloat-abi=hard -mfpu=vfpv3-d16 -DARMA53_$(A53_STATE) -Os -flto -ffat-lto-objects
+ECFLAGS :=  -Wextra -march=armv7-a -mfloat-abi=hard -mfpu=vfpv3-d16 -DARMA53_$(A53_STATE)
 LDFLAGS :=  -Wl,--start-group,-lxil,-lxilffs,-lxilsecure,-lxilpm,-lgcc,-lc,--end-group -L$(LIBPATH) -L./ -Wl,--build-id=none -march=armv7-a -mfloat-abi=hard -mfpu=vfpv3
2.7.4
shabbirk
Hi @dongkesi
Can you try adding this to <plnx-proj-root>/project-spec/meta-user/recipes-bsp/fsbl/fsbl_%.bbappend
YAML_COMPILER_FLAGS_remove = " -Os -flto -ffat-lto-objects"
dongkesi
Hi @shabbirk
Thanks for your reply. It doesn't work. My ultimate goal is to remove this option from .cproject, and then the entire project will have no this option.
components/plnx_workspace/fsbl/fsbl/.cproject
perencia-wc
A little late, but in case anyone is in the same situation I think that, after looking at the embeddedsw bb classes, I've found a way to remove those flags doing this on the bbappend file.
do_compile_prepend() {
    echo "Reconfiguring compiler flags"
    # Do not know why these two exports, but they are also in the other invocations to xsct of the
    # inherited recipes
    export RDI_PLATFORM=lnx64
    export SWT_GTK3=0
    # In the do_compile of xsctapp.bbclass, xsct is executed with eval; but that doesn't work for me.
    xsct -eval "setws ${XSCTH_WS}; configapp -app fsbl -set compiler-misc {-c -fmessage-length=0 -MT"$@" -Os}"
Here I let the xsctapp bb class to create the fsbl project with the -Os -flto -ffat-lto-objects, then I remove them before compiling. I don't know how to prevent them to be added in the first time, I also thought zynqmp_fsbl.tcl would be the place, but it isn't. I don't know what that file accomplish though, because it definitely seems related to creating the fsbl project in the sdk.
By the way, I want to do that because for some reason the fsbl fails like commented in the first posts here if compiled with link time optimizations (-flto -ffat-lto-objects). @dongkesi maybe you were in the same situation ?
EDIT: SDK has its own copy of embeddedsw, with its zynqmp_fsbl.tcl. I suppose that is the one used to create the fsbl project in the first time, with the lto flags. That would explain why patching the downloaded zynqmp_fsbl.tcl is useless.
