How to run a script during startup
           Hello.  On 4.4.0-xilinx, what is the right way to configure a script to run during startup?  I tried adding a script in init.d folder and linking it in rc5.d folder.  But it is not possible due to "Read-only file system" error.  Thanks for your insights!
@oskeewow  I believe this AR is what you need:
https://www.xilinx.com/support/answers/55998.html
