Observer pritya
How to run clang for xilinx u-boot
   I would like run clags for u-boot source code
I followed following processes.
1)
       1 . scan-build-3.5 make zynq_zed_defconfig
       2 . scan-build-3.5 make
ERROR : But it throws "lib/asm-offsets.c:1:0: error: bad value (armv5) for -march= switch
2)
       1 . make HOSTCC=clang-3.5 CROSS_COMPILE=arm-linux-gnueabihf- CC=clang-3.5  zynq_zed_defconfig
       2 . make HOSTCC=clang-3.5 CROSS_COMPILE=arm-linux-gnueabihf- CC=clang-3.5 -j8
ERROR : clang: warning: argument unused during compilation: '-ffixed-r9'
error: unknown target CPU 'armv5'
and I read document in doc/README.clang.
Is any other tools are available similar to clang.
Re: How to run clang for xilinx u-boot
See if this patch helps.You might need to modify this patch to have zynq config,
https://patchwork.ozlabs.org/patch/598860/
Best Regards
Shabbir
Observer pritya
Regret for late reply since i  was out of station.
I tried above patch, already everything is applied but in FreeBSD 11.
NOTE : For cross compiler, I have exported PATH with <petalinux_install_path>/tools/linux-i386/gcc-arm-linux-gnueabi/bin/
I am not able to find "arm-gnueabi-freebsd-as"  niether in "/usr/local/bin/" nor "<petalinux_install_path>/tools/linux-i386/gcc-arm-linux-gnueabi/bin/".
Whereas with present exported path I am getting same error as
OUTPUT :
# make HOSTCC=clang-3.5 CROSS_COMPILE=arm-linux-gnueabihf- CC=clang-3.5 -j8
  CHK     include/config/uboot.release
  CHK     include/generated/timestamp_autogenerated.h
  UPD     include/generated/timestamp_autogenerated.h
  HOSTCC  scripts/basic/fixdep
  CFG     u-boot.cfg
Makefile:928: recipe for target 'u-boot.cfg' failed
make: *** [u-boot.cfg] Error 1
make: *** Waiting for unfinished jobs....
As Xilinx officially doesnt support running clang from u-boot, petalinux doesnt come with this toolchain. You have to export it externally.
Best Regards
Shabbir
Observer pritya
I am bit confused about tool chain.
Can you please explain which to be exported explicitly "arm-linux-gnueabi-" or "arm-freebsd-eabi-"
Can you please share download link  ?
