Visitor yzfreedom
How to run linux in core1
Hi, dear all
     As Title, I want to run linux in core1, and I do somehing like follow:
    (1) make a project in vivado sdk, and create fsbl and app_core_0 in core0.
    (2)Add Code in fsbl to startup cpu1
    (3)change the memory size of app_core_0, start is 0x100000, size is 0x1FF00000.
    (4)Modify the uboot configs, change the memory configs, start is 0x20000000, size is 0x20000000
    (5)change the kernel device tree, change the memory reg, start is 0x20000000, size is 0x20000000
But  the result is core0 is running ok, but core1 didn't boot, I can't see any uboot info.
So can run linux in core1?  And how to run linux in core1?
Re: How to run linux in core1
 XIlinx Technical Reference Documents ( TRD ) talks about Running Bare metal code on one core , Linux on second core, same way
Running different linux images on two different cores , TRD avalibale from Xilinx Doc.s
That provides pre release images for the same.
Thanks & Regards
Satish G
G Satish Kumar
Visitor yzfreedom
    Thanks for you answer my question.
    I didn't find the document in the official website of xilinx, would you provide the website address?
    Thank you very much.
