Observer etexley
How to select SD-0/1 as primary in FSBL on Zynq 7000 SOC?
Hi to those concerned,
I'm trying to force FSBL to make SD Controller {0,1} number 1 primary on boot.  I'm loading my FSBL from QPI boot mode, and booting from a low-speed eMMC card.
In my project, first I export the HDF from vivado.  Then i take these steps:
1)  Open HW design (pointing at the exported HDF File.)
2)  xsct:  hsi create_sw_design sw_design_1 -proc ps7_cortexa9_0
3)  Include FFS Library: hsi add_library xilffs
4)  MMC Boot Mode: hsi set_property -name APP_COMPILER_FLAGS -value "-DMMC_SUPPORT" -objects [hsi current_sw_design]
5)  Export the FSBL COde
6)  Make.  Everything builds.
But how do i enforce SD 1 not 0? I looked at the source carefully, it's not obvious to me.  There is a function InitSD("0:")  which is called with a string.  is this string pointing at the controller?
Thanks and regards, Eric T
Observer etexley
Re: How to select SD-0/1 as primary in FSBL on Zynq 7000 SOC?
Well that took some digging through the FSBL source.  As of this release:
xilffs_v3_7
In addition to settting MMC_SUPPORT, in this file:
zynq_fsbl_bsp/ps7_cortexa9_0/libsrc/xilffs_v3_7/src/ff.c
I forcibly map the SD partition to the #1 controller (0 based)
fs->fs_type = 0U; /* Clear the file system object */
fs->drv = 1;
stat = disk_initialize(fs->drv); /* Initialize the physical drive */
Bango!  Now I can split my out my FSBL to QSPI and the rest of my partitions to eMMC.
Since every reference design I see has the emmc mapped to the 1st controller (MIO 10-15) I would think this would be documented somewhere?
Observer etexley
I generated the FSBL code twice with Petalinux...once with SD Controller 1, the other with SD Controller 2.  I diffed the code bases, but I don't see a difference.  Is there a compiler switch being used that I'm not seeing?
Observer etexley
xilffs_v3_7
fs->drv = 1;
