Visitor strong_229
How to set or choose cross compiler in petalinux tool envrionment?
I have build the hardware in vivado,and follow the ug1144 succussfully booting petalinux(microblaze ) on VC707 Kit.Then I want to run the build in gpio_demo application on petalinux,but it does not work ,I think the cross compiler is  the problem,but I  do not know which  cross compiler should be chose ,anybody can help me ,thanks!
Scholar watari
Re: How to set or choose cross compiler in petalinux tool envrionment?
Hi @strong_229
You can use "microblaze-xilinx-elf" or "microblazeel-xilinx-gnu" and find them in "$PETALINUX_INSTALL_DIR/tools/linux-i386".
Best regards,
Visitor strong_229
It is works! thanks a lot!!!
HI @strong_229 ,
As this is solved for you, could you kindly click on Accept as solution under @watari thread while logged in to close the topic. You might also want to give him a kudos to thanks him
Florent
