How to set up a custom script when the system starts in Petalinux2015.4.
I would like to make the system automatically complete some tasks when it starts, in the script defined. But I don't know where to write the script in petalinux2015.4
Re: How to set up a custom script when the system starts in Petalinux2015.4.
To have the PetaLinux build tools incorporate pre-build binary code, follow this general flow:
PetaLinux 2013.04 (and prior)
  1. Ensure that the root file system includes an interpreter for your script (e.g., Perl, Python, etc.).
  2. Use the petalinux-new-app to create an application. The new application will be located in ${PETALINUX}/software/user-apps/<APP>/. The -e option for petalinux-new-app will automatically select the application from menuconfig and will allow the application to be automatically built when the PetaLinux system is built.
  3. Place the scripts into ${PETALINUX}/software/user-apps/<APP>/
  4. Modify the makefile for the new application located inside ${PETALINUX}/software/user-apps/<APP>/.
    • Ensure that the all: and clean: sections of the makefile are empty.
    • Update the romfs: section to copy the scripts into ${PETALINUX}/software/petalinux-dist/romfs/.
Below is an example of the modifications:
all:
clean:
romfs:
     $(ROMFSINST) -d -p 0755 mystartup /etc/init.d/mystartup
     $(ROMFSINST) -s /etc/init.d/mystartup /etc/rcS.d/S99mystartup
Note: The scripts in /etc/rcS.d/ run in alphabetical order.
PetaLinux 2013.10 (and later)
  1. Ensure that the root filesystem includes an interpreter for your script (e.g., Perl, Python, etc.).
  2. Use petalinux-create -t apps -n <APP> to create an application.  The new application will be located in <PETALINUX_PROJECT_DIR>/components/apps/<APP>/. The --enable option for petalinux-create will automatically select the application from menuconfig and will allow the application to be automatically built when the PetaLinux system is built.
  3. Place the script(s) into <PETALINUX_PROJECT_DIR>/components/apps/<APP>/
  4. Modify the makefile for the new application located inside <PETALINUX_PROJECT_DIR>/components/apps/<APP>/.
    • Ensure that the all:, build:, and clean: sections of the makefile are empty.
    • Update the install:: section to copy the scripts into <PETALINUX_PROJECT_DIR>/build/linux/roofts/targetroot/.
all: build install
build: $(APP)
clean:
.PHONY: install image
install: $(APP)
 $(TARGETINST) -d -p 0755 mystartup /etc/init.d/mystartup
 $(TARGETINST) -s /etc/init.d/mystartup /etc/rc5.d/S99mystartup
Note: The scripts in /etc/rc5.d/ run in alphabetical order.
Thanks and Regards
Balkrishan
I've got help from you.Thank you very much.
I'm using PetaLinux 2016.04 and trying to get a custom script to run on startup.
Following the steps below, in step 2 I create an app (which I later do see when I run petalinux-config - c rootfs).
It seems it doesn't get created in <PETALINUX_PROJECT_DIR>/components/apps/<APP> but in<PETALINUX_PROJECT_DIR>/project-spec/meta-user/recipes-apps/<APP>
I place the script I want to run at startup in here, then update the Makefile as in the example (not as in step 4, I don't see a /build/linux/rootfs/targetroot/ folder).
APP = boot-scripts-my
# Add any other object files to this list below
APP_OBJS = boot-scripts-my.o
all: build install
build: $(APP)
clean:
install: $(APP)
$(APP): $(APP_OBJS)
	$(CC) $(LDFLAGS) -o $@ $(APP_OBJS) $(LDLIBS)
But after booting this (on Zedboard), I don't see any mystartup script file in any subfolder of /etc/, and no boot-scripts-my either. (I know the Makefile is being read when I do petalinux-build, as it complained originally about an error in that file, which I then fixed.)
As you are using 2016.4, it is based of Yocto and the steps have changed. Refer to pages 58-60 of the User Guide: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1144-petalinux-tools-reference-guide.pdf
This should get you moving in your attempt. Reply back if you need any help performing those steps.
Debraj
