How to set up the FIQ
Can anyone help me please?
I am trying to write an FIQ driver with petalinux 2014.4. My first step is one that counts timer interrupts so I have looked at lots of sites and come up with the code below. When I use insmod to load my driver the system crashes and I can’t see why.
If anyone can see what I am doing wrong it would be of great help
Thank you
/////////////////////////////////// Driver function ///////////////////////////////
#define TIMER_TCSR0    0x42810000       // address of timer 0's control and status register
#define TIMER_TLR0       0x42810004       // address of timer 0's load register
#define TIMER_TCR0       0x42810008       // address of timer 0's counter register
#define LOAD_VAL         0xE2329AFF
unsigned long *pTIMER_TCSR0;              // pointer to timer 0 control and status register
unsigned long *pTIMER_TLR0;                  // pointer to timer 0 load register
unsigned long *pTIMER_TCR0;                // pointer to timer 0 counter register
static struct fiq_handler fh       = { .name = "drv" };
static int               intcount = 0;
static int __init drv_init(void)
       if (claim_fiq(&fh))
           printk(KERN_ALERT "claim_fiq failed\n");
       else
           printk(KERN_ALERT "claim_fiq OK\n");
       /* Map timer register addresses and size to pointers */
       pTIMER_TCSR0 = ioremap_nocache(TIMER_TCSR0,0x4);     /* map timer 0 control and status register */
       pTIMER_TLR0 = ioremap_nocache(TIMER_TLR0,0x4);        /* map timer 0 load register              */
       pTIMER_TCR0 = ioremap_nocache(TIMER_TCR0,0x4);     /* map timer 0 count register             */
       /* Set up the FIQ reg's */
       get_fiq_regs(&fiqregs);
       fiqregs.ARM_r8 = &intcount;             /* Load address of Counter*/
       fiqregs.ARM_r9 = pTIMER_TCSR0;
       set_fiq_regs(&fiqregs);
       set_fiq_handler(&fiq, &fiq_end - &fiq);
       enable_fiq((28));   /*The FIQ Is PO FIQ number 28  */
       /* Write values to timer registers to set it up */
       iowrite32(LOAD_VAL, pTIMER_TLR0);                   /* place load value in load register */
       temp = ioread32(pTIMER_TLR0);                          /* debug: read load value to check   */
       iowrite32(0x000000B0, pTIMER_TCSR0);            /* load TLR */
       iowrite32(0x000000D0, pTIMER_TCSR0);           /* Generate mode,downcounter,reload generate */
       /* set interrupt count to 0 */
       intcount = 0;
       return 0;
/////////////////////////////////// Assembler function ////////////////////////////
#include <linux/linkage.h>
#include <asm/assembler.h>
                                                .text
                                                .global fiq
                                                .global fiq_end
ENTRY(fiq)
                                                /* Clear timer IRQ (pTIMER_TCSR0) by oring with T0INT */
                                                LDR r10, [r9];
                                                ORR r10, r10, #0x00000100;
                                                STR r10, [r9];
                                                /* Increment the counter (intcount++) */
                                                LDR r10, [r8];
                                                ADD r10, #1;
                                                STR r10, [r8];
                                                /* Return from the routine */
                                                SUBS pc, lr, #4;
fiq_end:
