How to solve dual Marvell 88e1512 PHY Ethernet problem in petalinux?
Platform: petalinux 2019.1
Board: Customed board--ZU7EV
Our Board used 2 GEM port(gem2 and gem3), these 2 ports used only 1 mdc/mdio interface.
GEM2: phy addr 1
GEM3: phy addr 0
The MIO and device tree as following:
/include/ "system-conf.dtsi"
	mdio {
		#address-cells = <0x2>;
		#size-cells = <0x2>;
		compatible = "cdns,macb-mdio";
		reg = <0x0 0xff0d0000 0x0 0x1000>;
		/*clocks = <&clk 0x1f>, <&clk 0x31>, <&clk 0x2d>;*/ /* GEM 2 1st 3 clocks */
		clock-names = "pclk", "hclk", "tx_clk"; /* Don't touch */
	     	ethernet_phy0: ethernet-phy@0 {
			compatible = "marvell,88e1510";
			device_type = "ethernet-phy";
		        reg = <0>;
	     	ethernet_phy1: ethernet-phy@1 {
		        reg = <1>;
&gem2 {
	local-mac-address = [00 0a 36 00 00 01];
	phy-mode = "rgmii-id";
	status = "okay";
	phy-handle = <&ethernet_phy1>;
&gem3 {
	local-mac-address = [00 0a 36 00 00 00];
	status = "okay";
	phy-handle = <&ethernet_phy0>;
But unfortunately, these ports can not  run in linux and u-boot
But if we just open 1 gem port in vivado project, then both ports can be used separately
I checked all the posts in this forum about this issue, which mentioned that need to install two patches:
0001-net-macb-Add-MDIO-driver-for-accessing-multiple-PHY-.patch
0002-Documentation-devictree-Add-macb-mdio-bindings.patch
So my question are:
  1. Do we need these patch in petalinux 2019.1?
  2. Is there any problems in the device tree?
Looking forward to your reply, Thx a lot!
Re: How to solve dual Marvell 88e1512 PHY Ethernet problem in petalinux?
Hi @jlynnc
Can you try removing both compatible & device_type property from the PHY node and see if that helps in detecting PHY's?
Best Regards
Shabbir
Hi @jlynnc
Best Regards
Shabbir
Thx for the reply!
The initial situation has some minor mistakes.
When using gem3 alone, the network port has no problem in uboot and kernel.
But when using gem2 alone, the network port has no problem in uboot, but eth0 is not found in the kernel.
I tried to remove both compatible & device_type property from the PHY node as  you suggestion!
When using gem2 alone, the ethernet port worked well in the kernel!
Next I will test the situation where both network ports are configured.
I will be back soon!THX again!
Thx a lot!
The problem is solved!
Dual port are worked well.
But I still want ask that why we need to remove those 2 lines?
Hi @jlynnc
Driver is already taking care of detecting the PHY hence these cleanup's are required in DT
https://github.com/Xilinx/linux-xlnx/blob/master/drivers/of/of_mdio.c#L135
