avcon_lee
Voyager
Voyager
How to start telnet program automatically
hi, everyone
I use my own board, similar to zcu102.
When the program starts from SD card, PC can ping the board. But telnet doesn't work, show connection failure.
The only way is through the serial port into the program system, through the telneted & command, using the command of Telnet + IP on PC can connect successfully.
Now I want to ask how to make telnet program run automatically after power on?
Is there any relevant setting in petalinux-config / petalinux-config - C rootfs/ petalinux-config -c kernel ?
stephenm
You can just create a script that sets this up, and add this into your rootfs to execute upon boot:
petalinux-create --template install:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug1144-petalinux-tools-reference-guide.pdf
stephenm
