How to tftpboot a freertos ELF (was made by Xilinx SDK) on ZCU106?
Hi guys,
I am quite a  beginner to embedded development with ZynqMP. I have a ZCU106 and I created a Freertos project base on LWIP echo sample.  The project was tested via QSPI boot with FSBL+PMU+Project ELF and it works well. However, I'd like to boot my FreeRTOS project through U-Boot.
I tried to create U-boot ELF file by PetaLinux. (Followed document UG1209 step-by-step). I tested U-boot ELF with the PetaLinux image.ub (FSBL+PMU+bl31.elf+u-boot.elf+image.ub) and it was booted from QSPI successfully. Then I tried to replace image.ub with the FreeRTOS ELF and it does not work.
I also tried to load FreeRTOS ELF via tftpboot after U-Boot fails to boot to FreeRTOS application. But it just reset after I enter the commands. Here's what I've got:
device 0 offset 0x1e40000, size 0x3c00000
SF: 62914560 bytes @ 0x1e40000 Read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
ZynqMP> tftpboot 0x0000 sample.elf
Using ethernet@ff0e0000 device
TFTP from server 192.168.1.220; our IP address is 192.168.1.52
Filename 'sample.elf;
Load address: 0x0
Loading: ##################################
2.4 MiB/s
done
Bytes transferred = 1575392
ZynqMP>  bootelf 0
##Starting application at 0x00000000 ...
"Synchronous Abort" handler, esr 0x02000000
ELR:  ffffffffa2bb1000
LR: 10085504
Resetting CPU ....
Any idea how to boot FreeRTOS by U-boot? At least through tftpboot?
Re: How to tftpboot a freertos ELF (was made by Xilinx SDK) on ZCU106?
