How to use HLS autogenerated linux drivers in Petalinux recipe
Hi all,
I have a couple of HLS IP cores. HLS automatically generates both Baremetal as well as Linux (UIO) pseudo drivers. When HDF is imported into petalinux I can see the drivers in: <petalinux-peject>/project-spec/hw-description/drivers/myipcore_v1_0 ....etc.
I was wondering how to best re-use these drivers in a yocto recipe, basically, I would like to write a small application which #includes and links to the exported HLS driver files.
Re: How to use HLS autogenerated linux drivers in Petalinux recipe
The HLS will generate baremetal drivers and linux UIO wrapper (which will use the UIO kernel driver). In your case (Petalinux), only the UIO wrapper is relevant.
You would need to update the devicetree to use the UIO driver, and you can import the UIO wrapper into SDK to debug/test.
I have a wiki here that details how to use the UIO driver, and test in SDK:
http://www.wiki.xilinx.com/Testing+UIO+with+Interrupt+on+Zynq+Ultrascale
This isnt specific to HLS, this uses an AXI GPIO, you would replace this with your HLS IP.
There is also alot of other threads on this topic. For example
https://forums.xilinx.com/t5/Vivado-High-Level-Synthesis-HLS/HLS-2017-2-Linux-drivers-for-my-exported-IP/td-p/812877
