How to use LM70.c
our board have tmp123 through spi on ps, may I know how to use LM70.c? How to compile it as module? I need create a module project myself ?
https://github.com/spotify/linux/blob/master/drivers/hwmon/lm70.c
Re: How to use LM70.c
Hi @lynn.zhang
Please follow the steps mentioned in this link:https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1144-petalinux-tools-reference-guide.pdf (Sections:Creating and Adding Custom Modules & Building User Applications )
Thanks & regards
Aravind
hanks for reply. Based on following:
https://github.com/Xilinx/linux-xlnx/blob/master/Documentation/devicetree/bindings/hwmon/lm70.txt
Where should I put following? at system-user.dtsi?
spi_master {
temperature-sensor@0 {
compatible = "ti,lm70";
reg = <0>;
spi-max-frequency = <1000000>;
Also lm70.c is xilinx kernel driver, I need create an module on my own like your said?
