Observer qswsjs
How to use PL330 in ZYNQ?
I want to to transfer data from pl to ddr via DMA(PL330). There is almost no pl330 material,no good example how to use the pl330 linux driver pll330.c . so i don't where i can start with.
Have anybody used  pl330? any example or datasheet will be great help,thanks.
Scholar norman_wong
Re: How to use PL330 in ZYNQ?
Some threads on the linux driver side of things for recent kernel versions:
http://forums.xilinx.com/t5/Embedded-Linux/PS-DMA-driver-in-Linux/td-p/481520
http://forums.xilinx.com/t5/Embedded-Linux/PL330-DMAC-Test-Code/m-p/491154
The PL330 signalling is reasonably documented in the Zynq TRM. I think that info is derived from the PL330 doc at ARM itself.
Observer qswsjs
thanks a lot for your reply! I have anoteher question,Do you know a document to describes the DMA(PL330) API ? or a guide how to program it (step by step)?
Scholar norman_wong
Not sure what you are asking. If you are asking about the PL330 microcode/opcodes, that is also covered in the PL330 TRM at ARM. The HTML version:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0424a/index.html
and the PDF version:
http://infocenter.arm.com/help/topic/com.arm.doc.ddi0424a/DDI0424A_dmac_pl330_r0p0_trm.pdf
