Anonymous
Not applicable
How to use SystemACE to reboot ML510 board
I am using the following (hacky) patch to reboot an ML510 board using the SystemACE:
diff --git a/arch/powerpc/platforms/44x/virtex.c b/arch/powerpc/platforms/44x/virtex.c index cf96cca..749a330 100644 --- a/arch/powerpc/platforms/44x/virtex.c +++ b/arch/powerpc/platforms/44x/virtex.c @@ -51,6 +51,16 @@ static int __init virtex_probe(void) return 1; } +void (*board_reset_system)(char *); +EXPORT_SYMBOL(board_reset_system); + +static void virtex_reset_system(char *cmd) +{ + if (board_reset_system) + board_reset_system(cmd); + ppc4xx_reset_system(cmd); +} + define_machine(virtex) { .name = "Xilinx Virtex440", .probe = virtex_probe, @@ -58,5 +68,5 @@ define_machine(virtex) { .init_IRQ = xilinx_intc_init_tree, .get_irq = xilinx_intc_get_irq, .calibrate_decr = generic_calibrate_decr, - .restart = ppc4xx_reset_system, + .restart = virtex_reset_system, }; diff --git a/drivers/block/xsysace.c b/drivers/block/xsysace.c index b20abe1..f3b4ab9 100644 --- a/drivers/block/xsysace.c +++ b/drivers/block/xsysace.c @@ -950,6 +950,19 @@ static struct block_device_operations ace_fops = { .getgeo = ace_getgeo, }; +extern void (*board_reset_system)(char *); +static struct ace_device *the_ace_device; + +/* -------------------------------------------------------------------- + * Board reset using ACE (forced FPGA reconfigure) + */ +static void ace_reset_system(char *cmd) +{ + printk(KERN_EMERG "ace_reset_system: attempting suicide\n"); + ace_out(the_ace_device, ACE_CTRL, ACE_CTRL_FORCECFGMODE | + ACE_CTRL_CFGMODE | ACE_CTRL_CFGSTART | ACE_CTRL_CFGSEL); +} + /* -------------------------------------------------------------------- * SystemACE device setup/teardown code */ @@ -1040,6 +1053,9 @@ static int __devinit ace_setup(struct ace_device *ace) val |= ACE_CTRL_DATABUFRDYIRQ | ACE_CTRL_ERRORIRQ; ace_out(ace, ACE_CTRL, val); + board_reset_system = ace_reset_system; + the_ace_device = ace; + /* Print the identification */ dev_info(ace->dev, "Xilinx SystemACE revision %i.%i.%i\n", (version >> 12) & 0xf, (version >> 8) & 0x0f, version & 0xff);
Any chance of such a change (or an equivalent cleaned-up version :smileywink: going into the main Xilinx git?
Is there some reason you don't want to clean it up and push it to the mainline?
I prefer not to put stuff into our tree if it can go into mainline as it's more for us to maintain when merging from mainline.
