How to use sdk/sysroots in vivado sdk to cross compile xilinx/dma code
I'm using petalinux 2018.3 to build my image
Now, SDK has been generated and some library such as opencv can be cross-compiled in SDK
But, when i'm trying to use dam API mentioned in this DOC https://www.kernel.org/doc/Documentation/DMA-API.txt
There are some errors occur.
The SDK setting and error is like this
Is there any advice or tutorial I can follow?
This method is wrong
In order to use dma in userspace the first thing you should do is build a kernel module for dma driver then compile your userspace code
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842418/Linux+DMA+From+User+Space
Chapter 4 in the above link is the right example, not Chapter 3
Hi eleicoto@outlook.com ,
Please check this forum post. Hope it helps you.
https://forums.xilinx.com/t5/Embedded-Linux/no-includes-for-linux-application/td-p/726294
Thanks & Regards
Anil B
Thanks & Regards
Anil B
Yes I can, but the problem is that some file seems missing
I think this may not be my situation because the image & SDK build process has been completed successfully.
And I can compile OpenCV code using sysroots
