How to write in the memory from a Petalinux application ?
I'm learning how the AXI interface works and I've created a simple design with AXI Lite and memory mapped registers just to transfer data from PS to PL.
For this, I've created an AXI4 peripheral using: Tools -> Create and Package IP -> Create a new AXI4 peripheral ...
This IP has 5 registers of 32 bits each. According to the address editor, the memory starts at 0x43C0_0000 and end at 0x43C0_FFFF (range 64k).
As a first test, I have connected these registers to the LEDs and added some logic like: if register X contains the data Y, then LED1 turns on, ...
Now what I am looking for is some example code to create the application in C / C ++ in the SDK to be run on the Petalinux.
So, I have two questions:
1- Is it necessary to add this AXI peripheral to the device tree ?
2- I've read others threads talking about 2 kind of device drivers to write in the memory: /dev/mem and UIO (uio_pdrv_genirq). Is there any simple guide/sample code to understand how to build this simple application using any of these drivers?
Thanks in advance.
To start out, you can just use the existing "devmem" command, this should already exist in your PetaLinux environment. The usage is:
devmem 0x43c00000                # read the first register
devmem 0x43c00004 32 0x12345678  # write the 2nd register with 0x12345678
The "devmem" program actually uses "/dev/mem" to perform the access. Note the address should always be a multiple of 4, since your registers are 32-bits wide.
There is quite a lot of overhead to launching a new program each time, just to do a single 32-bit read or write. If this becomes an issue, you replace devmem with your own program. It would be the same as devmem, but it keeps running, performing many read/write operations, until you decide to exit. This way the overhead occurs only once on startup, not on each read/write.
To answer the questions:
1- Maybe later on, but for now, not needed.
2- The /dev/mem option has been described above. A UIO driver gives much the same memory-mapped access, plus it allows you to "receive" an interrupt userspace (as opposed to in a true kernel driver). There are minor differences in how addressing works, but functionally the only difference is interrupt handling.
Those are both just scratching the surface. A "real" driver in the kernel has access to many more features, and generally provides an abstraction, so that userspace code does not need to know any details about your 32-bit register details. Rather it should provide "functions" such as "send a message" or "read sensor x" for example. You can revisit this much later, for now, I'd recommend starting with simple devmem.
Advisor
Advisor
Hi @shairva
  Adding to @rfs613 's insightful response, the other benefit of using UIO vs. /dev/mem besides interrupts, is removing the hard-coded offsets in the code, and leave them in the BSP, i.e. device tree. This may not be important for a one-off application but makes the code more portable for modifications and future projects.
  I've written recently on my blog about userspace memory I/O along with some example code.
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
