dtubbs
HowTo Add -I/path/to/include/folder to PetaLiunx 2018.2 Yocto build
Greetings,
I've added an app to my PetaLinux 2018.2 project, copied some source files into it, and I'm trying to build but failing.  The build error indicates it can't find a header file.
So I edited the Makefile in project-spec/meta-user/recipes-apps/myappname/files, and added the appropriate -I /path/to/include/folder on $(CC) compile line.  But when I build, the compiler still can't find the file, and it looks like the -I entry isn't being added to the compile operation.
How do I do this in the Yocto/BitBake world?
Thanks for your help!
-Dave
hokim
Remove -I path from your Makefile
Instead, you can add header files or folder to SRC_URI like SRC_URI += "file://*.h" or SRC_URI += "file://include_folder/"
gkuhn
"SRC_URI", at least in my app is a list of files prefixed with "file://". These files are all within a "files" directory. How can I add an include directory? Where do I put it? You mention "file://include_folder/" but where is this include folder relative to?
gkuhn
Ideally, I'd like to have the include directory either as a child of the files directory, or adjacent within the source hierarchy.
stephenm
You can place this anywhere. If you want to have it in the same dir, then use "SRC_URI := ${THISDIR}"
gkuhn
Thanks. This worked: SRC_URI := "file://${THISDIR}/include"
stephenm
Ok, great. Can you mark this as solved please?
gkuhn
It's not my thread to resolve, I hijacked it :)
petalinx_newbie
Do I also need to add this in .bb file?
do_install_append() {
install -d ${D}${bindir}
install -m 0755 ${S}/setup.py ${D}${bindir}
