Scholar ronnywebers
Howto build a user module for Ubuntu rfs instead of petalinux rootfs
I managed to build a user module and get it loading / unloading on a petalinux rootfs, as described in UG1144.
The first steps are :
# create a user module template for 'mymodule' -> see <project>/project-spec/meta-user/recipes-modules
petalinux-create -t modules --name mymodule --enable
# build the user module
petalinux-build
according to UG1144, the build process output goes here :
I can see 4 'rpm' files, which seem to be packages that can be installed.
Then UG1144 continues with these commands, to build the 'mymodule' into the petalinux image :
cd <project_root>
petalinux-build -c rootfs
petalinux-build -x package
When I try this out, everything works fine on my hardware target, I can indeed  'modprobe' and 'rmmod' my own generated module.
Now question : what do I need to do to get the same working on a Ubuntu RFS which I'm using, instead of a petalinux rfs? (The Ubuntu RFS is working, but I don't know how to add 'mymodule' correctly)
I don't think I can tell petalinux to use my Ubuntu image and run the 'petalinux-build -c rootfs' command ?
Do I need to use one of the .rpm files?
Also I found out that in the petalinux rfs, there are a bunch of files in the /lib/modules/<kernel version> folder :
I think these must be correct too before 'mymodule' can load? It's unclear to me what these files do / mean. Should I just copy these from the 'petalinux' image to my 'ubuntu' image? or how do I get these files corectly setup or generated on my Ubuntu image? Is this part of the 'rpm' install procedure?
Re: Howto build a user module for Ubuntu rfs instead of petalinux rootfs
See if this help you out:-
Edit this FIT image input file to have ubuntu root file system path:-
build/tmp/deploy/images/plnx_aarch64/fitImage.its-1.0-r0
And convert this input file to image.ub using this command:-
mkimage -f build/tmp/deploy/images/plnx_aarch64/fitImage.its-1.0-r0  image.ub
