Visitor liujun0621
I am confused when console print "usb 2-1: reset high-speed USB device number 3 using ci_hdrc"
when i write data to usb mobile disk in the zedboard,the console print as follows:
kernel version :2015.2
hello,I look for the print in the kernel source version :2015.2,but no result.
I am confused about ci_hdrc
ci=chip idea
what is the meaning about hdrc?
what is the print meaning?
thanks!
Re: I am confused when console print "usb 2-1: reset high-speed USB device number 3 using ci_hdrc"
HDRC = Highspeed Dual Role Controller)
https://github.com/enclustra-bsp/xilinx-linux/blob/master/Documentation/devicetree/bindings/usb/ci-hdrc-imx.txt
https://forums.xilinx.com/t5/Embedded-Linux/Building-device-tree/td-p/566082
Thanks and Regards
Balkrishan
