I am having a problem with CDMA driver. Crash due to irq value of zero
I generated a new device tree from the sdk which includes cdma and bram blocks connected in slave mode to the arm cores. Using interrupt 28. The sdk device tree did not generate the section for the interrupt. I had to add it. Here it is:
                axi_cdma_1: axicdma@4e200000 {
                        #address-cells = <1>;
                        #interrupt-cells = <1>;
                        #size-cells = <1>;
                        compatible = "xlnx,axi-cdma";
                        interrupt-parent = <&ps7_scugic_0>;
                        interrupts = <0 28 0>;
                        ranges = <0x4e200000 0x4e200000 0x10000>;
                        reg = <0x4e200000 0x10000>;
                        dma-channel@4e200000 {
                                compatible = "xlnx,axi-cdma-channel";
                                xlnx,datawidth = <0x20>;
                                xlnx,device-id = <0x0>;
                                xlnx,max-burst-len = <0x10>;
                bram_ctrl_1: axi-bram-ctrl@40000000 {
                        compatible = "xlnx,axi-bram-ctrl-3.0", "xlnx,xps-bram-if-cntlr-1.00.a";
                        reg = <0x40000000 0x1000>;
                        xlnx,bram-addr-width = <0xa>;
                        xlnx,bram-inst-mode = "EXTERNAL";
                        xlnx,ecc = <0x0>;
                        xlnx,ecc-onoff-reset-value = <0x0>;
                        xlnx,fault-inject = <0x0>;
                        xlnx,memory-depth = <0x400>;
                        xlnx,s-axi-ctrl-addr-width = <0x20>;
                        xlnx,s-axi-ctrl-data-width = <0x20>;
                        xlnx,s-axi-id-width = <0xc>;
                        xlnx,s-axi-supports-narrow-burst = <0x0>;
                        xlnx,single-port-bram = <0x1>;
The manual adition is striked. The driver loads then crashes in:
        chan->irq = irq_of_parse_and_map(node, 0);
        err = devm_request_irq(xdev->dev, chan->irq, cdma_intr_handler,
                               IRQF_SHARED,
                               "xilinx-cdma-controller", chan);
        if (err) {
                dev_err(xdev->dev, "unable to request IRQ, %d\n", chan->irq);
                return err;
The reason chan->irq == 0. I added debug statement to make sure that what I added to the device tree works.
====> creating irq mapping of axicdma
of_irq_map_raw: par=/amba@0/ps7-scugic@f8f01000,intspec=[0x00000000 0x0000001c...],ointsize=3
of_irq_map_raw: ipar=/amba@0/ps7-scugic@f8f01000, size=3
 -> addrsize=2
 -> got it !
 -> addrsize=2
 -> got it !
Then crash:
xilinx-cdma 4e200000.axicdma: unable to request IRQ, 0
xilinx-cdma 4e200000.axicdma: Probing channels failed
Unable to handle kernel NULL pointer dereference at virtual address 00000004
pgd = c0004000
[00000004] *pgd=00000000
Your help is appreciated. Thanks
Nidal
