xilinxlpc
I can't control gpio in linux. Why?
I can read and write emio register in u-boot with md.l and mw.l.
When I config the emio register in u-boot, I can control the gpio pin.
But when I mmap(APP) the 0xe000a000(emio base address), or ioremap(KERNEL DRIVER), I read the registers 0x00000000. Of cause, the gpio can't controlled by me.
What' wrong with it?
Thank you very much.
Camille
rfs613
Hello Camille,
Can you try it using "devmem" utility. This command should already be installed on your system.
# devmem 0xe000a000
0x00000280
If this works, then it suggests some error in your application. You can look at the source code for devmem (http://free-electrons.com/pub/mirror/devmem2.c)
xilinxlpc
The emio can work normally after I must use "echo 960 > /sys/class/gpio/export" to create gpio960.
Have any ways to control the emio?
rfs613
Using the /sys/class/gpio method is one of many possible ways to access the GPIO. This makes use of a driver in the kernel, which accesses the same hardware registers at physical address 0xE000A000. The source code for this driver is available in the standard xilinx kernel tree.
I'm afraid I do not understand exactly what problem you are facing.
h.alkan
I have encountered same problem, and I found the missing step.
Before access GPIO/EMIO register it will need set/update gpio clocks with set bit 22(GPIO_CPU_1XCLKACT) over APER_CLK_CTRL(0x0000012C) reg under  "System Level Control Registers(0xF8000000)".
uint32_t* sysctl = (uint32_t *)mmap(NULL, 0x1000, PROT_READ | PROT_WRITE, MAP_SHARED, fd_mem, (0xF8000000 & ~(0x1000 - 1)));
uint32_t* gpioclk = &sysctl[APER_CLK_CTRL>>2];
uint32_t clks = *gpioclk;
*gpioclk = clks|(1<<22);
Best regards
